Asus Transformer Flip Book TP200S Battery Replacement
  1. Asus Transformer Flip Book TP200S Battery Replacement, Battery: step 1, image 1 of 2 Asus Transformer Flip Book TP200S Battery Replacement, Battery: step 1, image 2 of 2
    • Remove the back 6mm and 8mm screws with a J000 screwdriver.
  2. Asus Transformer Flip Book TP200S Battery Replacement: step 2, image 1 of 1
    • Remove the back cover of the flip book by gently using a metal spudger.
  3. Asus Transformer Flip Book TP200S Battery Replacement: step 3, image 1 of 1
    • Unscrew the battery from the motherboard using a J000 screwdriver on the 3mm screws.
  4. Asus Transformer Flip Book TP200S Battery Replacement: step 4, image 1 of 2 Asus Transformer Flip Book TP200S Battery Replacement: step 4, image 2 of 2
    • The battery comes attached to the motherboard and needs to be disconnected before you can remove it.
    • Disconnect the battery from the motherboard by gently pulling out the connection with tweezers.
    • Gently remove the Wifi cables hooked to the rim of the battery
    • Remove the battery
2 other people completed this guide.
Alejandro Lopez
662 Reputation
5 Guides authored
USF Tampa, Team S17-G2, Boczar Spring 2018 Member of USF Tampa, Team S17-G2, Boczar Spring 2018
USFT-BOCZAR-S18S17G2
3 Members
6 Guides authored
3 Comments
how if my laptop not charge but the battery have replace before
Chen _El - Reply
its tooeasy! Thank You!
fotonngn - Reply
Its too easy! Tnks!
fotonngn - Reply
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 25
All Time: 3,094
