Introduction
This guide explains how to remove the battery of the Asus ROG Strix GL702VM-BHI7N09 for replacement. All you have to do is take off a few screws, pretty much.
Image 1/2: Using a Phillips #1 screwdriver, remove the ten 12 mm screws from the back panel. Image 2/2: Using a Phillips #1 screwdriver, remove the ten 12 mm screws from the back panel.
  • Flip the laptop over to the back panel, with the serial numbers facing up.
  • Using a Phillips #1 screwdriver, remove the ten 12 mm screws from the back panel.
Image 1/3: Wedge the sharp edge of the plastic opening tool into the seam between the back panel and the rest of the laptop, then gently pry the panel up. Image 2/3: There will be a snapping sound as you remove the back panel, but that is just the seal loosening. Image 3/3: Continue breaking the seals by sliding the plastic opening tool around the entire laptop under the seam until the back panel is free.
  • The snap seals don't need a lot of pressure to open, and may break if forced. Be gentle with the opening tool.
  • Wedge the sharp edge of the plastic opening tool into the seam between the back panel and the rest of the laptop, then gently pry the panel up.
    • There will be a snapping sound as you remove the back panel, but that is just the seal loosening.
  • Continue breaking the seals by sliding the plastic opening tool around the entire laptop under the seam until the back panel is free.
  • Once you have broken all the seals, carefully lift the panel off.
Image 1/2: Image 2/2:
  • Using a Phillips #1 screwdriver, remove the one 4 mm screw that is holding the battery.
Image 1/1: The wire connection to the motherboard will come off with little resistance when the battery is lifted out.
  • To remove the battery, lift it away from the center of the computer.
    • The wire connection to the motherboard will come off with little resistance when the battery is lifted out.
Niko Banks
159 Reputation
1 Guide authored
Cal Poly, Team S13-G2, Forte Spring 2017 Member of Cal Poly, Team S13-G2, Forte Spring 2017
CPSU-FORTE-S17S13G2
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 6
Past 7 Days: 34
Past 30 Days: 123
All Time: 289
