Introduction
In the event of system errors in crashes, your hard drive may be damaged or corrupted. Using a 1.5mm flathead screwdriver, you can quickly remove and replace this device's hard drive. It is fairly small and compact, so this particular guide should not take you longer than five minutes.
Again with the JIS 00, unscrew the three 5.7mm screws holding the hard drive in place. These can be found on small brackets on the four corners of the drive.
Slide the hard drive to the left, then remove it by lifting it from the compartment it is resting in.
