Asus Memo Pad ME172V Battery Replacement
Video Overview
  1. Asus Memo Pad ME172V Battery Replacement, Battery: step 1, image 1 of 3 Asus Memo Pad ME172V Battery Replacement, Battery: step 1, image 2 of 3 Asus Memo Pad ME172V Battery Replacement, Battery: step 1, image 3 of 3
    • With plastic tools remove the back cover.
    • If you have a memory card inside - remove it first.
  2. Asus Memo Pad ME172V Battery Replacement: step 2, image 1 of 3 Asus Memo Pad ME172V Battery Replacement: step 2, image 2 of 3 Asus Memo Pad ME172V Battery Replacement: step 2, image 3 of 3
    • Disconnect the battery connector.
    • The battery is stuck to the LCD display frame with a double side adhesive tape.
    • With plastic tools separate the battery.
  3. Asus Memo Pad ME172V Battery Replacement: step 3, image 1 of 1
5 other people completed this guide.
ZFix
191,278 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
322 Members
2,528 Guides authored
2 Comments
Hello, i want know if it is the same operation for asus memo pad 7 me572c ?
bechir77bejaoui - Reply
j'ai un probleme avec mon asus mémo pad 172v quand j'allume elle reste allumé le signe asus apparait avec le cercle de démarrage et elle reste comme ca elle ne s'ouvre pas est ce que probléme de batterie ,j'ai éssayé le flash mais meme problème
lord - Reply
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 10
All Time: 15,049
