Asus MeMO Pad 7 (ME572C) Battery Replacement
  1. Asus MeMO Pad 7 (ME572C) Battery Replacement, Rear Panel: step 1, image 1 of 2 Asus MeMO Pad 7 (ME572C) Battery Replacement, Rear Panel: step 1, image 2 of 2
    • Make sure your device is turned off. Then with a plastic opening tool, carefully remove the back panel by carefully working your way around the perimeter.
    • The panel will be glued on and requires pressure to open.
  2. Asus MeMO Pad 7 (ME572C) Battery Replacement: step 2, image 1 of 3 Asus MeMO Pad 7 (ME572C) Battery Replacement: step 2, image 2 of 3 Asus MeMO Pad 7 (ME572C) Battery Replacement: step 2, image 3 of 3
    • After removing the rear panel, use a plastic openning tool to remove the frame of the tablet.
    • Start in the middle of the top side and insert a plastic opening tool between the screen and the frame.
    • Carefully run the plastic opening tool along all the edges of the tablet.
  3. Asus MeMO Pad 7 (ME572C) Battery Replacement: step 3, image 1 of 1
    • When you take the rear panel and the frame out, place the rear panel and the frame away from the device.
    You do not need to separately remove the back and the frame. You can do it in 1 step if you start around the screen and remove the frame and back together.
    Visegradi Istvan - Reply
    Where can I find rear panel please help?
    Simeon Tembo - Reply
    Exact, on peut déposer le volet arrière en 1 seul fois. Commencer sans outil, juste avec les mains en forçant légèrement sur un angle inférieur (droit ou gauche peut importe) afin de déboîter un premier clips-plastic. Puis avec un outil fin en plastique (pas de métal de préférence !) faire le tour de l’écran afin de déboîter tous les clips-plastic. Merci pour ce post.
    Loïc MALECOT - Reply
    To keep the frame notches intact, pry the frame first sideways, then to the back, lifting the outside notches of the frame over the inside notches of the device.
    My rear panel seems welded together with the frame, so came off as a whole. I noticed 8 inside/device notches of the total 4x6 notches broke in the process.
    Before disassemble, I noticed in the middle on the longer side, next to the power button, already a gap, through which I saw the copper shining of the sidekeys part. Maybe because of temperature expansion or strain of the elastic corner clips of the sleeve I used.
    Eduard - Reply
    Correction: “To keep the frame notches .. device.” = “Notches on the plastic motherboardchassis are snapped over notches of the outside frame locking both together. To keep the chassis notches intact, .. chassis.“
    Eduard -
  4. Asus MeMO Pad 7 (ME572C) Battery Replacement, Battery: step 4, image 1 of 3 Asus MeMO Pad 7 (ME572C) Battery Replacement, Battery: step 4, image 2 of 3 Asus MeMO Pad 7 (ME572C) Battery Replacement, Battery: step 4, image 3 of 3
    • Disconnect the ZIF connectors to release the data cables holding the battery in. Use tweezers to do this.
    • You can also use your hand to remove ZIF connectors.
    • ZIF connectors are delicate so be careful when you are removing them.
  5. Asus MeMO Pad 7 (ME572C) Battery Replacement: step 5, image 1 of 1
    • Find the place where the battery connector is. Disconnect the battery connectors by carefully pulling up on them using a spudger or plastic opening tool.
  6. Asus MeMO Pad 7 (ME572C) Battery Replacement: step 6, image 1 of 3 Asus MeMO Pad 7 (ME572C) Battery Replacement: step 6, image 2 of 3 Asus MeMO Pad 7 (ME572C) Battery Replacement: step 6, image 3 of 3
    • Using a plastic opening tool carefully pry the battery loose. The battery is glued to the pad; slight pressure will be needed to remove the battery.
    • The casing of the battery is soft and can easily tear. Tearing can lead to the chemicals in the battery to leak out.
4 other people completed this guide.
Tyler Tripp
395 Reputation
2 Guides authored
USF Tampa, Team 14-23, Meier Fall 2015 Member of USF Tampa, Team 14-23, Meier Fall 2015
USFT-MEIER-F15S14G23
4 Members
14 Guides authored
One Comment
But whats the secret to cleaning off the glue and resealing it?
Pico Herbie - Reply
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 49
All Time: 35,752
