Asus L410MA-MH09-CA Speakers Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
11
Past 30 Days:
50
All Time:
490
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Missing Steps
Oops! This guide is currently missing one or more important steps.
Introduction
Go to step 1 ↓
This is a replacement guide for the speakers in your ASUS L410MA-MH09-CA - Meant to be followed if your device's speakers are having issues such as crackled sound or no sound.
If you have not already done so, please troubleshoot your device using this guide. Only when you have exhausted these troubleshooting steps should you proceed with replacement.
Tools
    1. Asus L410MA-MH09-CA Speakers Replacement, Battery: step 1, image 1 of 1
      • Remove all ten 6 mm Phillips #1 screws that secure the lower case.
      • Insert an opening pick in the gap between the lower case and chassis.
      • Slide the opening pick around the entire perimeter of the laptop until the lower case fully releases.
      • Remove the lower case.
      Ask FixBot
    2. Asus L410MA-MH09-CA Speakers Replacement: step 2, image 1 of 1
      • Remove the 4 mm Phillips #1 screws that secure the battery.
      Ask FixBot
    3. Asus L410MA-MH09-CA Speakers Replacement: step 3, image 1 of 1
      • Grip the white battery connector and pull it directly out of its battery port.
      Ask FixBot
    4. Asus L410MA-MH09-CA Speakers Replacement: step 4, image 1 of 1
      • Lift the battery out carefully.
      Ask FixBot
    1. Asus L410MA-MH09-CA Speakers Replacement, Speakers: step 5, image 1 of 1
      • Remove any electrical tape and disconnect any ribbon cables in the way.
      • They are there to secure the speaker wire in place.
      • Pull the white speaker connector directly out of its port.
      Ask FixBot
    2. Asus L410MA-MH09-CA Speakers Replacement: step 6, image 1 of 1
      • Lift the speakers out of the device.
      Ask FixBot
After removing the speakers, you can install the replacement. To reassemble your device, follow these instructions in reverse order.
Jimmy
361 Reputation
3 Guides authored
Gateway, Team 8-2, Gonzalez Fall 2024 Member of Gateway, Team 8-2, Gonzalez Fall 2024
GCC-GONZALEZ-F24S8G2
5 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 50
All Time: 490
