Introduction
This guide will teach you how to reach the hard drive of your Asus. The hard drive is required for the computer to function, so knowing how to replace your hard drive is vital to computer repair. If you're looking to upgrade the storage capabilities of your computer or your computer's hard drive isn't functioning, the guide will give you the tools to do so.
  1. Using a flathead screwdriver, spudger, or large coin such as a quarter, remove the large screw on the bottom of the laptop.
    • Using a flathead screwdriver, spudger, or large coin such as a quarter, remove the large screw on the bottom of the laptop.
    • After the screw is removed, take off the back panel.
  2. Locate the hard drive in the lower left corner. Unscrew four 6mm Phillip #0 screws from the hard drive mounting.
    • Locate the hard drive in the lower left corner.
    • Unscrew four 6mm Phillip #0 screws from the hard drive mounting.
  3. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    Browse Our Store
  4. Unplug and remove the hard drive by pulling up on the black tab on top of the hard drive.
    • Unplug and remove the hard drive by pulling up on the black tab on top of the hard drive.
    • A spudger may assist in prying up the black tab.
  5. Unscrew two 3mm Phillips #0 screws to remove the casing on the hard drive. Unscrew two 3mm Phillips #0 screws to remove the casing on the hard drive.
    • Unscrew two 3mm Phillips #0 screws to remove the casing on the hard drive.
Ryan Lawrence
605 Reputation
5 Guides authored
Cal Poly, Team 5-10, Maness Spring 2015 Member of Cal Poly, Team 5-10, Maness Spring 2015
CPSU-MANESS-S15S5G10
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 23
All Time: 1,787
