Asus EeeBook X205TA Screen Assembly Replacement
  1. Asus EeeBook X205TA Screen Assembly Replacement, Screen Assembly: step 1, image 1 of 2 Asus EeeBook X205TA Screen Assembly Replacement, Screen Assembly: step 1, image 2 of 2
    • Unscrew all 10 screws located on the bottom of the laptop using 2mm Phillips Screwdriver.
    • Keep in mind that some of the screws vary in length, so keep track of which screws were placed in each hole.
  2. Asus EeeBook X205TA Screen Assembly Replacement: step 2, image 1 of 1
    • Insert the plastic opening tool in the crevice between the back of the laptop and the rest of the case.
    • Carefully pry open the case from several points.
    • Slowly remove the back of the laptop, revealing the parts inside.
  3. Asus EeeBook X205TA Screen Assembly Replacement: step 3, image 1 of 3 Asus EeeBook X205TA Screen Assembly Replacement: step 3, image 2 of 3 Asus EeeBook X205TA Screen Assembly Replacement: step 3, image 3 of 3
    • Unscrew the four screws using Philips #2 screwdriver that connect the screen to the inside of the case for the laptop.
  4. Asus EeeBook X205TA Screen Assembly Replacement: step 4, image 1 of 1
    • Unplug the No-Fuss Ribbon connector of the screen from the motherboard.
    • Carefully lift the screen away from the case.
3 other people completed this guide.
Lorena Santiago
712 Reputation
4 Guides authored
USF Tampa, Team 2-2, Sullivan Fall 2016 Member of USF Tampa, Team 2-2, Sullivan Fall 2016
USFT-SULLIVAN-F16S2G2
3 Members
10 Guides authored
One Comment
What's that small black screen hanging out from the laptop
Tayler Grant - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 2,356
