Introduction
The Asus Eee PC 900 uses a small solid state drive instead of a lrger hard drive. Use this guide to replace the SSD in the Asus Eee PC 900.
Remove the small sticker on the right side of the SSD/RAM compartment cover.
Remove the two 4.76 mm Phillips #0 screws securing the SSD/RAM compartment cover.
Using a plastic opening tool, lift up the bottom of the SSD/RAM compartment cover.
Lift the cover away from the laptop.
Remove the two 4.76 mm Phillips #0 screws that secure the SSD.
Slide the SSD out of its socket and lift it out of the compartment.
