Asus Chromebook Flip C100P Battery Replacement
  1. Asus Chromebook Flip C100P Battery Replacement, Lower Case: step 1, image 1 of 1
    • Unscrew the eight bottom cover screws (one of them is under the hand) using a screwdriver with a J1000 tip.
    • Unscrew the middle screw towards the top of the device using a screwdriver with a T5 tip.
  2. Asus Chromebook Flip C100P Battery Replacement: step 2, image 1 of 1
    • Use the plastic opening tool to remove the four bottom rubber feet.
  3. Asus Chromebook Flip C100P Battery Replacement: step 3, image 1 of 1
    • Unscrew the four screws under the feet using a screwdriver with a J100 tip.
  4. Asus Chromebook Flip C100P Battery Replacement: step 4, image 1 of 1
    • Use the plastic opening tool to pry up the palm rest assembly.
  5. Asus Chromebook Flip C100P Battery Replacement: step 5, image 1 of 1
    Tool used on this step:
    Buy
    • Disconnect the two cables from the motherboard with tweezers
  6. Asus Chromebook Flip C100P Battery Replacement, Battery: step 6, image 1 of 1
    • Unscrew the four J1 Screws of the Audio Cards
  7. Asus Chromebook Flip C100P Battery Replacement: step 7, image 1 of 1
    • Unscrew the three Battery Screws by using a screwdriver with a J00 tip.
  8. Asus Chromebook Flip C100P Battery Replacement: step 8, image 1 of 1
    • Lift the battery cable out of Mother Board
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 24
All Time: 11,691
