Fix Your Stuff
Right to Repair
Parts & Tools
Introduction
All of the key components that could fail are accessed by removing the Aspen A720 back cover. The process will include removing a couple of screws and then utilizing the plastic opening tool to pry the cover apart from the body of the device.
  1. Use a Phillips #00 screwdriver to remove the two 4mm screws found on the top edge of the tablet near the power button. Make sure to keep track of screws.
    • Use a Phillips #00 screwdriver to remove the two 4mm screws found on the top edge of the tablet near the power button.
    • Make sure to keep track of screws.
  2. Manta Driver Kit
    112 bits for every fix.
    Upgrade Your Toolbox
    Manta Driver Kit
  3. Use the plastic opening tool to pry the white back from the silver frame. Start near the micro SD slot. Slide the plastic opening tool around the perimeter of the casing until the back is disconnected. Slide the plastic opening tool around the perimeter of the casing until the back is disconnected.
    • Use the plastic opening tool to pry the white back from the silver frame. Start near the micro SD slot.
    • Slide the plastic opening tool around the perimeter of the casing until the back is disconnected.
  4. Remove the rear casing.
    • Remove the rear casing.
Now all of the components are accessible for maintenance
Ben
280 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 263
