This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Community-Contributed Guide
Introduction
Go to step 1 ↓Guide for opening and disassembling the components of an Aqara G2H indoor camera (model CH-H01). It also applies to G2H-Pro cameras (model CH-C01).
2 tips:
- Read the entire guide before starting, to see (and understand) the disassembly sequence.
- Work while warm: plastic won't break at 25°C (77°F), but it will at 16°C (61°F). Don't hesitate to warm up the parts before disassembly (1 hour at 20 cm from a radiator, for example; 30°C/86°F is a good temperature for disassembling plastic).
Photo 1: remove the 4 short screws located under the camera. The foot separates easily.
Photo 2: unclip the 4 bottom snap fits using the opening wheel (yellow arrows). The top snap fits will detach on their own (red arrows).
Photo 3: the tools used.
Photo 1: remove the 4 long screws (yellow arrows).
Photo 2:
Unplug the connector using a pick to push the snap fit and gently lift at the same time.
Once unplugged, pull the black/red wires out of the notch to release the board. This is the microphone cable.
Photo 3:
Gently pull the motherboard away from the front shell, being careful of the two metal tabs (yellow arrows).
Unplug the infrared lighting module connector (magenta arrow) by pulling on it gently.
The black ribbon cable for communication with the camera module is visible (red arrow): it is removed from the main board side by gently lifting the brown flip-lock (orange arrow).
Photo 1: the flap that serves as the ribbon cable lock is lifted (orange arrow).
Photo 2: the ribbon cable is directional!
"TO-MAIN" plugs into the main board side.
"TO-SENSOR" plugs into the camera module side.
Photo 1:
Remove the 3 short screws (yellow arrows). Do not remove the other two screws holding the lens to its board.
Using a small pick, gently lift the circuit board at the visible white pins (purple arrows).
Photo 2: camera module removed next to its base.
Photo 1: remove the two screws (00) that hold the infrared diode board in place.
Photo 2: infrared module removed. You can see the diodes.
To reassemble your device, follow the instructions in reverse order.
