Fix Your Stuff
Right to Repair
Store
You're viewing a previously published version of this guide.  View latest version
Older Newer
Introduction
This is a replacement guide for the external body of the Apple iSight webcam. The external body of the Apple iSight is composed of the silver structure and the cap with the Apple logo. The overall process is quick and easy. Follow these steps for a successful replacement.
Parts
No parts specified.
  1. Remove two 3.55 mm screws that hold the body to the ball and socket joint using the PH000 screwhead.
    • Remove two 3.55 mm screws that hold the body to the ball and socket joint using the PH000 screwhead.
  2. Insert the tweezers into the crevice of the ball and socket joint, and prop up the tabs to remove the white ring from the body.
    • Insert the tweezers into the crevice of the ball and socket joint, and prop up the tabs to remove the white ring from the body.
  3. Press the Apple logo through to pull apart the body frame from the body of the webcam. Press the Apple logo through to pull apart the body frame from the body of the webcam.
    • Press the Apple logo through to pull apart the body frame from the body of the webcam.
Jesus Marcial
130 Reputation
1 Guide authored
IUPUI, Team S5-G1, Baechle Spring 2018 Member of IUPUI, Team S5-G1, Baechle Spring 2018
IUPUI-BAECHLE-S18S5G1
3 Members
3 Guides authored
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 23
All Time: 441
