Apple iPod Hi-Fi Batteries Replacement
  1. Apple iPod Hi-Fi Batteries Replacement, Batteries: step 1, image 1 of 1
    • Put your coin in the battery lock on the back of the the Hi-Fi. Turn the coin to the left to release the battery panel.
    • Remove the battery panel with your hands.
    • You can also use a metal spudger or flathead screwdriver to open the battery lock instead of a coin.
  2. Apple iPod Hi-Fi Batteries Replacement: step 2, image 1 of 1
    • Remove the six D batteries from the device.
6 other people completed this guide.
Timothy Scheuermann
710 Reputation
3 Guides authored
Cal Poly, Team S16-G1, Livingston Spring 2018 Member of Cal Poly, Team S16-G1, Livingston Spring 2018
CPSU-LIVINGSTON-S18S16G1
5 Members
16 Guides authored
3 Comments
good day.  Does the column charge the batteries when it is plugged in?
pay4e4ek777 - Reply
Nope, the hifi will not charge any batteries that are installed.
Josh Calvetti -
Hello, I realize these comments/texts are a bit old (2019) however, I have an Apple Speaker unit from 2006 that is practically new with very little usage but stopped working due to purchasing a Bluetooth adaptor and inserting it in the rear (Audio in) jack. It had been working “great” with the Bluetooth and my iPhone for a while until the speaker unit ceased to function-turn back on (no power). Can you kindly assist in assessing-determining what might have gone wrong and what would be required to fix this problem. Many thanks ahead. Look forward to your reply.
Roosevelt Adrianza - Reply
Past 24 Hours: 0
Past 7 Days: 19
Past 30 Days: 104
All Time: 4,469
