Introduction
Use this guide to replace the adhesive of your Apple Watch Series 3 and reseal it.
This guide shows the procedure on the standard, GPS-only version of the watch, but the cellular/LTE version is similar. Any important differences are noted in the text.
Tool used on this step:Adhesive Cleanup Kit (Set of 12)$4.99
Apply a little bit of isopropyl alcohol (>99%) to a Q-tip or use a cleaning pad to gently remove the adhesive leftovers on top of the force touch gasket.
Flip the Apple Watch upside down so the display lays flat while lifting up the case.
Remove the leftovers on the back of the display.
Use a pair of tweezers to carefully remove replacement adhesive with the blue protective film from the backing paper.
Hold the replacement adhesive diagonally to thread it over the display.
Slightly tilt the display forward so you can align the adhesive with the frame.
Position the replacement adhesive on top of the force touch gasket and use the pointed end of a spudger to move and press it into place.
Reconnect the battery as seen in the replacement guide you came from.
Remove the protective film from the adhesive.
