Fix Your Stuff
Right to Repair
Parts & Tools
You're viewing a previously published version of this guide.  View latest version
Older Newer
Introduction
The three WiFi antenna are very fragile and sensitive. Be very careful when removing and replacing them, as touching the replacement antenna can cause them to not function at peak efficiency. The old antenna do not require the same care, though you should avoid bending or forcing to remove the antenna because they could snap and ruin the device. Also be careful with the metal attached to the antenna can bend and cause the metal casing to not fit back together with the other pieces.
  1. The back pad is held in with glue so use caution when removing to prevent tearing. Low heat may be used to help remove the pad.
    • The back pad is held in with glue so use caution when removing to prevent tearing. Low heat may be used to help remove the pad.
    • Slowly peel off the rubber pad on the bottom of the device. Start from one corner and peel with your fingers. Use heat if necessary until pad is completely removed.
  2. After removing the rubber pad, unscrew the five 5mm phillips #00 screws in the holes of the back cover.
    • After removing the rubber pad, unscrew the five 5mm phillips #00 screws in the holes of the back cover.
  3. Lift up the back case from the perforated edge to remove it.
    • Lift up the back case from the perforated edge to remove it.
  4. Manta Driver Kit
    112 bits for every fix.
    Upgrade Your Toolbox
    Manta Driver Kit
  5. Remove logic board and metal casing from outer case by prying from one side using a spudger.
    • Remove logic board and metal casing from outer case by prying from one side using a spudger.
  6. Unhook the wires connecting the logic board to the metal casing by grabbing and pulling up on each connection with tweezers.
    • Unhook the wires connecting the logic board to the metal casing by grabbing and pulling up on each connection with tweezers.
  7. Carefully push back the three metal tabs with your fingers on the sides of metal case.
    • Carefully push back the three metal tabs with your fingers on the sides of metal case.
  8. Carefully pull the metal case away from the logic board.
    • Carefully pull the metal case away from the logic board.
  9. Unscrew the 5mm #00 screws from each of the three antennas located on the sides of the metal casing.
    • Unscrew the 5mm #00 screws from each of the three antennas located on the sides of the metal casing.
    • Pull away antennas from metal case.
  10. Pull up the less visible silver tape that holds the antenna cords in place at the ends of the device using your fingers. Remove clear yellow tape that holds the cords to the outer casing in the same manner.
    • Pull up the less visible silver tape that holds the antenna cords in place at the ends of the device using your fingers.
    • Remove clear yellow tape that holds the cords to the outer casing in the same manner.
Dillon Huffsmith
235 Reputation
1 Guide authored
USF Tampa, Team 12-4, Blackwell Fall 2014 Member of USF Tampa, Team 12-4, Blackwell Fall 2014
USFT-BLACKWELL-F14S12G4
5 Members
5 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 14
All Time: 1,364
