Anker Soundcore Q20i Battery Replacement
    1. Anker Soundcore Q20i Battery Replacement, Battery: step 1, image 1 of 1
      • Orient the headphones so that the side of the ear cushion is accessible.
      Ask FixBot
    2. Anker Soundcore Q20i Battery Replacement: step 2, image 1 of 1
      • Insert an opening tool into the groove where the left ear pad meets the left driver assembly.
      Ask FixBot
    3. Anker Soundcore Q20i Battery Replacement: step 3, image 1 of 2 Anker Soundcore Q20i Battery Replacement: step 3, image 2 of 2
      • Pry around the entire perimeter of the left ear pad until it fully releases.
      Ask FixBot
    4. Anker Soundcore Q20i Battery Replacement: step 4, image 1 of 2 Anker Soundcore Q20i Battery Replacement: step 4, image 2 of 2
      • Use a Phillips #00 screwdriver to remove the four screws securing the driver assembly.
      • Lift off the driver assembly, with care not to strain the connected cables.
      Ask FixBot
    5. Anker Soundcore Q20i Battery Replacement: step 5, image 1 of 1
      • Desolder the two battery contacts from the board.
      • If you're unfamiliar with soldering, review the How To Solder and Desolder Connections guide.
      • Use your index finger to lift the battery and remove it from the base.
      Ask FixBot
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Aditya Sah
171 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 20
Past 7 Days: 145
Past 30 Days: 669
All Time: 1,655
