1. First remove the back cover by squeezing the phone and sliding the cover backwards. First remove the back cover by squeezing the phone and sliding the cover backwards. First remove the back cover by squeezing the phone and sliding the cover backwards.
    • First remove the back cover by squeezing the phone and sliding the cover backwards.
  2. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    Browse Our Store
  3. Now that you have removed the back cover, you can start removing the battery. Use a fingernail to pry the battery out as shown. Now that you have removed the back cover, you can start removing the battery. Use a fingernail to pry the battery out as shown. Now that you have removed the back cover, you can start removing the battery. Use a fingernail to pry the battery out as shown.
    • Now that you have removed the back cover, you can start removing the battery. Use a fingernail to pry the battery out as shown.
  4. Now you can put the battery in. Make sure the metal points on the new battery are lined up with the three pins in the battery compartment. Push the battery in snuggly and replace the back cover. Now you can put the battery in. Make sure the metal points on the new battery are lined up with the three pins in the battery compartment. Push the battery in snuggly and replace the back cover. Now you can put the battery in. Make sure the metal points on the new battery are lined up with the three pins in the battery compartment. Push the battery in snuggly and replace the back cover.
    • Now you can put the battery in. Make sure the metal points on the new battery are lined up with the three pins in the battery compartment. Push the battery in snuggly and replace the back cover.
You have replaced the battery. Please charge the phone before using it.
Matthew Willis
98 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 50
