Amazon Kindle 8 Power Button Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
12
Past 7 Days:
69
Past 30 Days:
232
All Time:
1,854
Comments: 6
5 comments on steps, 1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
If the power button on your Amazon Kindle 8 is unresponsive or broken, use this guide to replace it.
The power button is important for turning the Kindle on and off and entering sleep mode. A faulty power button will prevent normal operation or cause the Kindle to remain on, which will drain its battery.
Before beginning, make sure the issue is with the power button and not a software issue by performing a restart and checking for software updates.
Be careful when handling internal components to avoid damaging surrounding parts.
Tools
    1. Amazon Kindle 8 Power Button Replacement, Front Cover: step 1, image 1 of 2 Amazon Kindle 8 Power Button Replacement, Front Cover: step 1, image 2 of 2
      • Insert the iFixit opening tool into any corner of the Kindle’s front cover.
      • Gently slide the tool along the edges and carefully separate the front cover from the inner front cover.
      • Keep even pressure to avoid any cracks.
      • Lift front cover once all clips are disengaged.
      • Lift the front cover gently so that it is not cracked.
      Ask FixBot
    2. Amazon Kindle 8 Power Button Replacement: step 2, image 1 of 2 Amazon Kindle 8 Power Button Replacement: step 2, image 2 of 2
      • Insert the spudger between the inner front cover and the screen.
      • Gently work your way around to loosen the inner front cover.
      • Carefully lift the inner front cover from the device.
      Ask FixBot
    1. Amazon Kindle 8 Power Button Replacement, Motherboard: step 3, image 1 of 2 Amazon Kindle 8 Power Button Replacement, Motherboard: step 3, image 2 of 2
      • Use a T4 Torx screwdriver to remove the seven 3 mm screws around the perimeter of the device.
      Ask FixBot
    2. Amazon Kindle 8 Power Button Replacement: step 4, image 1 of 2 Amazon Kindle 8 Power Button Replacement: step 4, image 2 of 2
      • Lift the screen and motherboard from the back cover.
      Ask FixBot
    1. Amazon Kindle 8 Power Button Replacement, Power Button: step 5, image 1 of 2 Amazon Kindle 8 Power Button Replacement, Power Button: step 5, image 2 of 2
      • On the back cover, from the outside of the kindle, use your finger to push the power button through its hole.
      • Remove the power button.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Luke
456 Reputation
5 Guides authored
1 Guide Comment
partial fix, that does not show how to remove and replace the button in the subject. Please integrate step-by-step guide.
SimoneGallina - Reply Share
Past 24 Hours: 12
Past 7 Days: 69
Past 30 Days: 232
All Time: 1,854
