Introduction
Disassembly of the Amazon Fire Tablet 5th Generation revealed a simple design with a LCD display, motherboard, battery, and unfused digitizer. The digitizer and battery adhesives needed some elbow grease to break through, but overall we were happy to award this design a 7 out of 10 for repairability.
  1. Amazon Fire Tablet (5th Generation) Repairability Assessment, Amazon Fire Tablet (5th Generation) Repairability Assessment: step 1, image 1 of 3 Amazon Fire Tablet (5th Generation) Repairability Assessment, Amazon Fire Tablet (5th Generation) Repairability Assessment: step 1, image 2 of 3 Amazon Fire Tablet (5th Generation) Repairability Assessment, Amazon Fire Tablet (5th Generation) Repairability Assessment: step 1, image 3 of 3
    • Front and back reference shots.
  2. Amazon Fire Tablet (5th Generation) Repairability Assessment: step 2, image 1 of 2 Amazon Fire Tablet (5th Generation) Repairability Assessment: step 2, image 2 of 2
    • There are only clips holding the assembly together. No adhesive makes for much easier device access.
    • The plastic back cover comes off to reveal the battery, motherboard, and display hiding on the other side.
    • We can also see smaller components, including a speaker and a camera.
  3. Amazon Fire Tablet (5th Generation) Repairability Assessment: step 3, image 1 of 2 Amazon Fire Tablet (5th Generation) Repairability Assessment: step 3, image 2 of 2
    • This battery isn't super easy to remove. It's held in with several adhesive strips that require force to separate.
    • We use a card to fight the adhesive and we can pry the battery out with a bit of effort.
    • At the top of the motherboard there's a little tamper evident sticker.
  4. Amazon Fire Tablet (5th Generation) Repairability Assessment: step 4, image 1 of 3 Amazon Fire Tablet (5th Generation) Repairability Assessment: step 4, image 2 of 3 Amazon Fire Tablet (5th Generation) Repairability Assessment: step 4, image 3 of 3
    • We can remove the motherboard after removing five Phillips screws, and disconnecting two ZIF and two press connectors.
    • Front-facing camera is modular and easily pops out.
    • Rear-facing camera is soldered to the board and is not going anywhere.
  5. Amazon Fire Tablet (5th Generation) Repairability Assessment: step 5, image 1 of 2 Amazon Fire Tablet (5th Generation) Repairability Assessment: step 5, image 2 of 2
    • Just the display assembly's left. How hard is a digitizer replacement?
    • Hard.
  6. Amazon Fire Tablet (5th Generation) Repairability Assessment: step 6, image 1 of 2 Amazon Fire Tablet (5th Generation) Repairability Assessment: step 6, image 2 of 2
    • The Amazon Fire Tablet earns a 7 out of 10 on our repairability scale (10 is the easiest to repair):
    • The plastic case assembly is held together by clips and no adhesive, and opening only requires prying with an iFixit opening tool.
    • The digitizer and LCD panel are not fused together.
    • All of the screws in the device are Phillips screws.
    • The battery is modular, but it is held in place by somewhat stubborn adhesive.
    • Removing the digitizer and LCD panel requires fighting through some very resilient adhesive.
    • Manufacturer does not provide user-accessible repair documentation.
Finish Line
13 other people completed this guide.
Scott Havard
47,617 Reputation
33 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 20
Past 30 Days: 116
All Time: 7,484
