Introduction
Before you begin, make sure the device is off. You will need to use the screen replacement guide as a prerequisite.
Lift the screen and digitizer from the case.
Hi Beldenr! We happen to have a handy guide for a lot of different types of connectors, including ZIF connectors.
Locate the power cable that links the battery to the motherboard.
Carefully unplug the battery power cable to disconnect the battery from the motherboard.
Battery removal is optional for the motherboard, but is a great addition to this guide for completeness.
Begin by locating the double sided pull tape locations.
Pull the black soft tabs to release the tape's adhesion.
Do this to all 4 tabs until the battery is completely free of adhesion to the device's backing.
11 other people completed this guide.
8 Comments
I’m confused. If it’s a battery replacement issue, why is the battery not listed on the parts list? Is that not necessary once you take the old one out? Where do I get a new battery to replace the one this is teaching me to remove? O.o
You’ll have to google one. Amazon does not offer one. They want to sell you a new Kindle instead.
I am buying one with the plastic tools (ebay), even if they suck, they should get through this process once.
ctgblue -
How do you know if ita battery or charging port? Mine dont do anything whe. Its
That’s my question also. How do you know if it is the battery or the port?
Fitted battery replacement now won't start up any clues where iv gone wrong?
The right side with the power switch on top?
Sonny Shear - Reply
Where is the right hand corner? Is it the corner nearest the USB connector? Farthest from USB connector?
Thanks!
Steve Ciciora - Reply
