Introduction
In this guide, we will show you how to remove and replace the Processor Fan and Heat-Sink Assembly.
Tools
Parts
No parts specified.
Align the battery pack tabs with the slots in the battery bay.
Push the NEW battery pack into the battery bay until the battery pack clicks into place.
Loosen the two captive screws that secure the memory-module door to the computer base.
Slide the memory-module door to release the tabs and lift the memory-module door out of the computer base.
Use your fingertips to carefully spread apart the spring-locks on the memory-module connector until the memory module pops up.
Align the notch on the NEW memory module with the tab on the memory-module connector.
Insert the module into the memory-module connector at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the module and reinstall it.
Align and insert the memory-module door tabs into the slots on the computer base.
Replace and tighten the two captive screws that secure the memory-module door to the computer base.
Using the pull-tab, lift the hard-drive assembly out of the hard-drive bay.
Remove the four screws that secure the hard drive to the hard-drive bracket.
Replace the four screws that secure the hard drive to the hard-drive bracket.
Align and tighten the four captive screws that secure the hard-drive assembly to the hard-drive bay.
Disconnect the processor fan and heat sink assembly cable from the system board connector.
In sequential order (indicated on the processor fan and heat sink assembly), loosen the four captive screws that secure the processor fan and heat sink assembly to the system board.
Lift the processor fan and heat sink assembly off the system board.
Peel the backing off the thermal cooling pads attached to the NEW processor fan and heat sink assembly.
Align the four captive screws on the processor heat sink with the screw holes on the system board and tighten the screws in sequential order (indicated on the processor fan and heat sink assembly).
Tighten the screw that secures the processor fan and heat sink assembly to the computer base.
Connect the processor fan and heat sink assembly cable to the system board connector.
