Alienware M11xR2 Display Assembly Replacement
  1. Alienware M11xR2 Display Assembly Replacement, Disconnecting Antenna Cable: step 1, image 1 of 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Disconnect the antenna cables from the Mini-Card(s).
  2. Alienware M11xR2 Display Assembly Replacement, Removing Mimi Card: step 2, image 1 of 1
    • The routing of the Mini-Card antenna cables and remove them from the routing guides on the computer base.
  3. Alienware M11xR2 Display Assembly Replacement, Turning Over The Computer: step 3, image 1 of 1
    • Turn the computer over and open the display as far as possible.
  4. Alienware M11xR2 Display Assembly Replacement, Pulling The Pull-Tab: step 4, image 1 of 1
    • Pull the pull-tab to disconnect the display cable from the connector on the system board.
  5. Alienware M11xR2 Display Assembly Replacement, Removing Screws: step 5, image 1 of 1
    • Remove the four screws that secure the display assembly to the computer base.
  6. Alienware M11xR2 Display Assembly Replacement, Removing Mini-Card cable: step 6, image 1 of 1
    • Gently slide the Mini-Card antenna cables out through the slot on the computer base.
  7. Alienware M11xR2 Display Assembly Replacement, Lifting Display Assembly: step 7, image 1 of 1
    • Lift the display assembly off the computer.
  8. Alienware M11xR2 Display Assembly Replacement, Sliding New Cables: step 8, image 1 of 1
    • Slide the antenna cables in through the slot on the computer base.
  9. Alienware M11xR2 Display Assembly Replacement, Securing Screws: step 9, image 1 of 1
    • Place the NEW display assembly in position and replace the four screws that secure the display assembly to the computer base.
  10. Alienware M11xR2 Display Assembly Replacement, Connecting New Display Cable: step 10, image 1 of 1
    • Connect the display cable to the connector on the system board.
  11. Alienware M11xR2 Display Assembly Replacement, Rerouting  The Mini-Card Cable: step 11, image 1 of 1
    • Turn the computer over and route the Mini-Card antenna cables through the routing guides on the computer base.
  12. Alienware M11xR2 Display Assembly Replacement, Connecting Mini-Card Cables: step 12, image 1 of 1
    • Connect the Mini-Card antenna cables to the Mini-Card(s).
darrius
5,213 Reputation
30 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
42 Members
1,985 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 428
