Introduction
Follow this guide to replace the speaker housing (aka speaker grille) on the right ear cup of your AirPods Max headset.
Unplug and remove all cables and accessories.
To help stabilize the ear cups and prevent scratching them, consider placing your AirPods Max on a soft, clean cloth.
Insert a SIM eject tool, bit, or a small, straightened paperclip into the hole on the top edge of the right ear cup (labeled R).
Push down with your tool and pull the headband connector straight out of its socket.
Set the right ear cup down on a soft, clean cloth to prevent scratches and help stabilize the cup during your repair.
Use a P5 pentalobe screwdriver to turn (not remove) the four speaker housing screws to the unlocked position:
Turn the top left and bottom right screws counterclockwise.
Turn the top right and bottom left screws clockwise.
Tool used on this step:iOpener$14.95
Option 1: Apply a few drops of high-concentration isopropyl alcohol (>90%) in the gap around the perimeter of the speaker housing. Wait one minute to allow the alcohol to soften the adhesive.
Option 2: Heat the speaker housing with an iOpener or hair dryer. Focus the heat around the perimeter, applying small amounts for short periods of time.
Tool used on this step:iSesamo Opening Tool$10.99
Insert the flat side of your opening tool into the gap between the left side of the speaker housing and the lip of the ear cup (opposite the R marking).
Pry up the speaker housing until you can grip it with your fingers, applying constant pressure to allow the adhesive to separate.
Tool used on this step:FixMat$36.95
Use a Torx Plus 1IP screwdriver to remove the 1.7 mm‑long screw securing the speaker housing cable cover.
Use a spudger to pry up and disconnect the speaker housing press connector.
Use tweezers and scissors to remove any sections of bunched-up or overlapping adhesive that would prevent the housing from sitting perfectly flat.
Apply thin, double-sided adhesive where you removed the original, using short sections to help match the curve of the lip.
Hold the speaker housing up and use your finger to press down and reconnect its press connector.
Slide the tab on the connector cover into its slot and lay the cover down.
Flip the speaker housing into the cup and press it into place around the perimeter.
Use a P5 pentalobe screwdriver to turn the four speaker housing screws to the locked position:
Turn the top left and bottom right screws clockwise.
Turn the top right and bottom left screws counterclockwise.
Hold the ear cup steady with one hand, and use your free hand to firmly push the headband connector into its slot, twisting it slightly—it should click into place.
Congratulations on completing your repair!
