Introduction
Follow this guide to replace the headband hinge in the right ear cup of your AirPods Max headset.
If the right ear cup's hinge is loose or rattling, you may need to replace it.
Unplug and remove all cables and accessories.
To help stabilize the ear cups and prevent scratching them, consider placing your AirPods Max on a soft, clean cloth.
Insert a SIM eject tool, bit, or a small, straightened paperclip into the hole on the top edge of the right ear cup (labeled R).
Push down with your tool and pull the headband connector straight out of its socket.
Set the right ear cup down on a soft, clean cloth to prevent scratches and help stabilize the cup during your repair.
Use a P5 pentalobe screwdriver to turn (not remove) the four speaker housing screws to the unlocked position:
Turn the top left and bottom right screws counterclockwise.
Turn the top right and bottom left screws clockwise.
Tool used on this step:iOpener$14.95
Option 1: Apply a few drops of high-concentration isopropyl alcohol (>90%) in the gap around the perimeter of the speaker housing. Wait one minute to allow the alcohol to soften the adhesive.
Option 2: Heat the speaker housing with an iOpener or hair dryer. Focus the heat around the perimeter, applying small amounts for short periods of time.
Tool used on this step:iSesamo Opening Tool$10.99
Insert the flat side of your opening tool into the gap between the left side of the speaker housing and the lip of the ear cup (opposite the R marking).
Pry up the speaker housing until you can grip it with your fingers, applying constant pressure to allow the adhesive to separate.
Tool used on this step:FixMat$36.95
Use a Torx Plus 1IP screwdriver to remove the 1.7 mm‑long screw securing the speaker housing cable cover.
Use a spudger to pry up and disconnect the speaker housing press connector.
Use a Torx Plus 3IP screwdriver to remove three speaker driver screws:
Two 6.0 mm‑long screws
One 6.0 mm‑long screw that's slightly thicker than the other two
Remove the 5.1 mm‑long standoff screw using one of the two methods below:
Option 1: Stick a small flathead screwdriver into one of the four notches on top of the screw and use it to slowly turn the screw.
Option 2: Use a Torq-Set 6 screwdriver to remove the screw, applying constant downward force to avoid damaging the screw.
Lift the top edge of the speaker and remove it, being careful not to touch the diaphragm.
Remove the two connector cover screws:
One 7.0 mm‑long Torx Plus 3IP screw
One 1.7 mm‑long Torx Plus 1IP screw
Use the point of a spudger to pry up and disconnect the battery press connector (the smaller one, not the one that folds under the board).
Tool used on this step:Flexible Extension$6.99
Use a Torx Plus 5IP screwdriver to remove the two screws securing the sides of the battery cells.
If the screw isn't coming out once fully loosened, use tweezers to pull it out.
Slide the battery cells out of their recesses one at a time and remove them.
Use a Torx Plus 1IP screwdriver to remove the two 1.7 mm‑long screws securing the power board connectors cover.
Use a spudger to pry up and disconnect the three press connectors on the power board.
Use a Torx Plus 3IP screwdriver to remove the two 5.7 mm‑long screws securing the power board.
Slowly pull the power board out of its recess and flip it over the side of the ear cup, giving you access to the connector on the underside.
Use the point of a spudger to press on alternating sides of the sliding connector tabs to "walk" it out of the socket.
Use a Torx Plus 1IP screwdriver to remove the two 1.7 mm‑long screws securing the connector cover.
The other end of the cover is plastic-riveted into place. Unless you're comfortable soldering off the rivets, this requires you to bend the cover.
Use your finger to lift and bend the cover enough that you can access the smaller connector near the back of the cover.
Use the point of a spudger to pry up and disconnect the hinge press connector (the smaller one, whose cable runs back towards the hinge).
Use your fingers to gently pull the copper hinge cable (in plastic tubing) out of its clip.
Use a Torx Plus 5IP screwdriver to remove the four 5.3 mm‑long screws securing the hinge.
Slide the point of a spudger into one of the hinge's lower screw holes.
Use the spudger to rotate the bottom edge of the hinge upwards to free the hinge.
Remove the hinge.
The black ribbon cable coming out of the left side of the hinge needs to be routed behind the lower screw post. Otherwise, it will likely tear. You may need to use tweezers to do this while you put the hinge in place.
There's a long ribbon cable that needs to run in front of the hinge. Make sure it doesn't get stuck under the hinge, or it may get damaged.
Insert the hinge into its recess at a slight downward angle and then rotate it into place, making sure all four screw holes line up.
Before moving on, go back to the previous step and make sure the cable are in the proper locations.
Use a Torx Plus 5IP screwdriver to install the four 5.3 mm‑long screws securing the hinge.
While holding the hinge's ribbon cable in place with tweezers, use a spudger to reconnect the press connector.
Use the point of a spudger to push on alternating sides of the copper cable's connector until it slides fully into the socket on the underside of the power board.
Flip the power board over and slide it into its recess, making sure the three cables that connect to the charging port don't get stuck underneath.
Make sure the three cables are oriented so they can connect to the board.
The gold speaker contacts should be sitting in their small groove.
Check that each screw has its rubber gasket installed.
Use a Torx Plus 3IP screwdriver to install the two 5.7 mm‑long screws securing the power board.
Use your finger to press down and reconnect the three power board press connectors.
Put the connector cover into place on the center of the power board.
With the exposed sides of the battery cells facing down, slide the battery cable under the lip of the ear cup so it sits on top of the charging port.
Place both battery cells into their recesses.
Use a Torx Plus 3IP screwdriver to install the three screws securing the battery cells:
Two 4.0 mm‑long screws
One 7.0 mm‑long screw
Use a spudger or your fingers to press down and connect the battery press connector.
Slide the battery connector cover's two tabs into their slots and lay the cover in place.
Gently lay the speaker driver into place, making sure the side with gold connector pins lines up with their contacts in the shell.
Use a Torx Plus 3IP screwdriver to install three speaker driver screws:
Install the 5.1 mm‑long standoff screw using a small flathead or Torq-Set 6 screwdriver.
Use tweezers and scissors to remove any sections of bunched-up or overlapping adhesive that would prevent the housing from sitting perfectly flat.
Apply thin, double-sided adhesive where you removed the original, using short sections to help match the curve of the lip.
Hold the speaker housing up and use your finger to press down and reconnect its press connector.
Slide the tab on the connector cover into its slot and lay the cover down.
Flip the speaker housing into the cup and press it into place around the perimeter.
Use a P5 pentalobe screwdriver to turn the four speaker housing screws to the locked position:
Turn the top left and bottom right screws clockwise.
Turn the top right and bottom left screws counterclockwise.
Hold the ear cup steady with one hand, and use your free hand to firmly push the headband connector into its slot, twisting it slightly—it should click into place.
Congratulations on completing your repair!
1 Guide Comment
Very detailed and easy to understand and follow instructions
