AirPods Max Headband Replacement
    1. AirPods Max Headband Replacement, Prepare your headset for disassembly: step 1, image 1 of 2 AirPods Max Headband Replacement, Prepare your headset for disassembly: step 1, image 2 of 2
      • Before starting your repair:
      • Unplug and remove all cables and accessories.
      • To help stabilize the ear cups and prevent scratching them, consider placing your AirPods Max on a soft, clean cloth.
      Ask FixBot
    1. AirPods Max Headband Replacement, Remove the earpads: step 2, image 1 of 3 AirPods Max Headband Replacement, Remove the earpads: step 2, image 2 of 3 AirPods Max Headband Replacement, Remove the earpads: step 2, image 3 of 3
      • The earpads are secured with magnets
      • Lift the earpads straight up and remove them.
      Ask FixBot
    1. AirPods Max Headband Replacement, Remove the ear cups: step 3, image 1 of 3 AirPods Max Headband Replacement, Remove the ear cups: step 3, image 2 of 3 AirPods Max Headband Replacement, Remove the ear cups: step 3, image 3 of 3
      • Insert a SIM eject tool, bit, or a small, straightened paperclip into the hole on the top edge of one of the ear cups.
      • Push down with your tool and pull the headband connector straight out of its socket.
      • The headband connector should slide out easily. If you're having trouble, reposition the tool and try again—you may need to angle the bit slightly.
      Ask FixBot
    2. AirPods Max Headband Replacement: step 4, image 1 of 1
      • Repeat the previous step to remove the other ear cup.
      Ask FixBot
    1. AirPods Max Headband Replacement, You're left with the headband: step 5, image 1 of 1
      • You're left with the headband for replacement.
      Ask FixBot
    1. AirPods Max Headband Replacement, Disassembly complete: step 6, image 1 of 1
      • Congratulations on completing disassembly! The remaining steps will show how to reassemble your AirPods Max.
      Ask FixBot
    1. AirPods Max Headband Replacement, Install the ear cups: step 7, image 1 of 3 AirPods Max Headband Replacement, Install the ear cups: step 7, image 2 of 3 AirPods Max Headband Replacement, Install the ear cups: step 7, image 3 of 3
      • The headband and ear cup should be oriented in the "closed" position (how they would be when stored in a case) when installing them.
      • Hold an ear cup steady with one hand, and use your free hand to firmly push the headband connector into its slot—it should click into place.
      • This can be tricky and may take a few tries. If you're having trouble, reposition the connector slightly and try again.
      Ask FixBot
    2. AirPods Max Headband Replacement: step 8, image 1 of 3 AirPods Max Headband Replacement: step 8, image 2 of 3 AirPods Max Headband Replacement: step 8, image 3 of 3
      • Repeat the previous step to install the other ear cup.
      Ask FixBot
    1. AirPods Max Headband Replacement, Install the earpads: step 9, image 1 of 3 AirPods Max Headband Replacement, Install the earpads: step 9, image 2 of 3 AirPods Max Headband Replacement, Install the earpads: step 9, image 3 of 3
      • Place the earpads into their cups—they should "snap" into place.
      • The right earpad goes on the cup with the Digital Crown and Noise Control buttons.
      Ask FixBot
Congratulations on completing your repair!
Spencer Day
202,372 Reputation
1,244 Guides authored
0 Guide Comments
Past 24 Hours: 58
Past 7 Days: 531
Past 30 Days: 1,989
All Time: 7,378
