AirPods Max Charging Port Replacement
  1. AirPods Max Charging Port Replacement, Prepare your headset for disassembly: step 1, image 1 of 2 AirPods Max Charging Port Replacement, Prepare your headset for disassembly: step 1, image 2 of 2
    • Before starting your repair:
    • Unplug and remove all cables and accessories.
    • Let your AirPods Max's battery drain below 25%—a charged lithium‑ion battery may catch fire if damaged.
    • For information on how to check your AirPods Max battery status, go to this guide and scroll down to Check the charge status.
    • To help stabilize the ear cups and prevent scratching them, consider placing your AirPods Max on a soft, clean cloth.
    Ask FixBot
  2. AirPods Max Charging Port Replacement, Remove the right earpad: step 2, image 1 of 2 AirPods Max Charging Port Replacement, Remove the right earpad: step 2, image 2 of 2
    • The earpads are secured with magnets
    • Lift the right earpad (labeled R) straight up and remove it.
    Ask FixBot
  3. AirPods Max Charging Port Replacement, Remove the right ear cup: step 3, image 1 of 3 AirPods Max Charging Port Replacement, Remove the right ear cup: step 3, image 2 of 3 AirPods Max Charging Port Replacement, Remove the right ear cup: step 3, image 3 of 3
    • Removing the ear cup isn’t required, but can make the repair easier. You can leave the cup attached and remove it later if needed.
    • Insert a SIM eject tool, bit, or a small, straightened paperclip into the hole on the top edge of the right ear cup (labeled R).
    • Push down with your tool and pull the headband connector straight out of its socket.
    • The headband connector should slide out easily. If you're having trouble, reposition the tool and try again—you may need to angle the bit slightly.
    Ask FixBot
  4. AirPods Max Charging Port Replacement, Set the right ear cup down: step 4, image 1 of 1
    • Set the right ear cup down on a soft, clean cloth to prevent scratches and help stabilize the cup during your repair.
    Ask FixBot
  5. AirPods Max Charging Port Replacement, Turn the housing screws to the open position: step 5, image 1 of 2 AirPods Max Charging Port Replacement, Turn the housing screws to the open position: step 5, image 2 of 2
    • Turn these screws slowly and gently, stopping when you feel resistance—about 1/4 turn. If turned too far, the locking mechanism will break.
    • Use a P5 pentalobe screwdriver to turn (not remove) the four speaker housing screws to the unlocked position:
    • Turn the top left and bottom right screws counterclockwise.
    • Turn the top right and bottom left screws clockwise.
    Ask FixBot
  6. AirPods Max Charging Port Replacement, Soften the speaker housing adhesive: step 6, image 1 of 3 AirPods Max Charging Port Replacement, Soften the speaker housing adhesive: step 6, image 2 of 3 AirPods Max Charging Port Replacement, Soften the speaker housing adhesive: step 6, image 3 of 3
    Tool used on this step:
    iOpener
    $14.95
    Buy
    • The perimeter of the speaker housing is secured to the cup with adhesive. This step shows a few methods to soften the adhesive so you can pry up the housing. If one isn't working, try a different method.
    • Option 1: Apply a few drops of high-concentration isopropyl alcohol (>90%) in the gap around the perimeter of the speaker housing. Wait one minute to allow the alcohol to soften the adhesive.
    • Option 2: Heat the speaker housing with an iOpener or hair dryer. Focus the heat around the perimeter, applying small amounts for short periods of time.
    • Don't heat the center of the speaker housing, or you'll damage the fragile mesh under the speaker cutouts and possibly the speaker.
    • For a detailed look at best practices for using a hair dryer, check out this guide.
    Ask FixBot
  7. AirPods Max Charging Port Replacement, Pry up the speaker housing: step 7, image 1 of 3 AirPods Max Charging Port Replacement, Pry up the speaker housing: step 7, image 2 of 3 AirPods Max Charging Port Replacement, Pry up the speaker housing: step 7, image 3 of 3
    iSesamo Opening Tool
    $9.99
    Buy
    • The gap between the speaker housing and ear cup is extremely small. You'll need a thin tool such as a metal opening pick, iSesamo, or iFlex to pry up the housing.
    • Don't grip the iFlex or similar metal tools by the edges—they're sharp and may cut you. Consider wearing gloves to protect yourself.
    • Insert the flat side of your opening tool into the gap between the left side of the speaker housing and the lip of the ear cup (opposite the R marking).
    • Pry up the speaker housing until you can grip it with your fingers, applying constant pressure to allow the adhesive to separate.
    • If the housing isn't coming up, repeat the previous step and try again. Don't try and force the housing out or you may damage it.
    Ask FixBot
  8. AirPods Max Charging Port Replacement: step 8, image 1 of 3 AirPods Max Charging Port Replacement: step 8, image 2 of 3 AirPods Max Charging Port Replacement: step 8, image 3 of 3
    • Don't try to fully remove the speaker housing yet—a delicate ribbon cable still connects it to the ear cup.
    • Lift the speaker housing out of the ear cup to fully separate the remaining adhesive.
    • Flip the housing over the side of the cup and prop it up so you can access the cable.
    Ask FixBot
  9. AirPods Max Charging Port Replacement, Remove the speaker housing cable cover: step 9, image 1 of 2 AirPods Max Charging Port Replacement, Remove the speaker housing cable cover: step 9, image 2 of 2
    FixMat
    $36.95
    Buy
    • Don’t let any screws snap onto the speaker driver diaphragm or they'll damage it. The screws will be drawn towards the center by the speaker's magnet.
    • Use a Torx Plus 1IP screwdriver to remove the 1.7 mm‑long screw securing the speaker housing cable cover.
    Ask FixBot
  10. AirPods Max Charging Port Replacement: step 10, image 1 of 2 AirPods Max Charging Port Replacement: step 10, image 2 of 2
    • Use tweezers to remove the cover.
    Ask FixBot
  11. AirPods Max Charging Port Replacement, Disconnect the speaker housing: step 11, image 1 of 2 AirPods Max Charging Port Replacement, Disconnect the speaker housing: step 11, image 2 of 2
    • Use a spudger to pry up and disconnect the speaker housing press connector.
    Ask FixBot
  12. AirPods Max Charging Port Replacement, Remove the speaker housing: step 12, image 1 of 1
    • Remove the speaker housing.
    Ask FixBot
  13. AirPods Max Charging Port Replacement, Remove the speaker driver screws: step 13, image 1 of 3 AirPods Max Charging Port Replacement, Remove the speaker driver screws: step 13, image 2 of 3 AirPods Max Charging Port Replacement, Remove the speaker driver screws: step 13, image 3 of 3
    • Grip the screws with tweezers while loosening and removing them. Don’t let the screws snap onto the diaphragm.
    • Use a Torx Plus 3IP screwdriver to remove three speaker driver screws:
    • Two 6.0 mm‑long screws
    • One 6.0 mm‑long screw that's slightly thicker than the other two
    • Remove the 5.1 mm‑long standoff screw using one of the two methods below:
    • Apply constant downward force to avoid damaging the screw.
    • Option 1: Stick a small flathead screwdriver into one of the four notches on top of the screw and use it to slowly turn the screw.
    • Option 2: Use a Torq-Set 6 screwdriver to remove the screw, applying constant downward force to avoid damaging the screw.
    Ask FixBot
  14. AirPods Max Charging Port Replacement, Remove the speaker driver: step 14, image 1 of 3 AirPods Max Charging Port Replacement, Remove the speaker driver: step 14, image 2 of 3 AirPods Max Charging Port Replacement, Remove the speaker driver: step 14, image 3 of 3
    • Lift the top edge of the speaker and remove it, being careful not to touch the diaphragm.
    • If you're having trouble, use the point of a spudger to start lifting the speaker.
    • Set the speaker aside in a place where it won't attract small metal objects.
    Ask FixBot
  15. AirPods Max Charging Port Replacement, Remove the battery connector cover: step 15, image 1 of 2 AirPods Max Charging Port Replacement, Remove the battery connector cover: step 15, image 2 of 2
    • Remove the two connector cover screws:
    • One 7.0 mm‑long Torx Plus 3IP screw
    • You may need tweezers to remove this screw.
    • One 1.7 mm‑long Torx Plus 1IP screw
    Ask FixBot
  16. AirPods Max Charging Port Replacement: step 16, image 1 of 3 AirPods Max Charging Port Replacement: step 16, image 2 of 3 AirPods Max Charging Port Replacement: step 16, image 3 of 3
    • Two tabs slot into place and secure the cover.
    • Slide the cover out of the slots and remove it.
    Ask FixBot
  17. AirPods Max Charging Port Replacement, Disconnect the battery: step 17, image 1 of 2 AirPods Max Charging Port Replacement, Disconnect the battery: step 17, image 2 of 2
    • Use the point of a spudger to pry up and disconnect the battery press connector (the smaller one, not the one that folds under the board).
    Ask FixBot
  18. AirPods Max Charging Port Replacement, Remove the battery screws: step 18, image 1 of 3 AirPods Max Charging Port Replacement, Remove the battery screws: step 18, image 2 of 3 AirPods Max Charging Port Replacement, Remove the battery screws: step 18, image 3 of 3
    Flexible Extension
    $6.99
    Buy
    • Use a Torx Plus 5IP screwdriver to remove the two screws securing the sides of the battery cells.
    • Depending on your screwdriver, you may need to use a flexible extension to get a proper fit in the screw.
    • If the screw isn't coming out once fully loosened, use tweezers to pull it out.
    Ask FixBot
  19. AirPods Max Charging Port Replacement: step 19, image 1 of 3 AirPods Max Charging Port Replacement: step 19, image 2 of 3 AirPods Max Charging Port Replacement: step 19, image 3 of 3
    • Use a Torx Plus 3IP screwdriver to remove the three screws securing the battery cells:
    • Two 4.0 mm‑long screws
    • One 7.0 mm‑long screw
    • Make sure you remove the correct screw (which goes through the board), and not the one just to the left of it.
    • You may need to use tweezers to remove this screw.
    Ask FixBot
  20. AirPods Max Charging Port Replacement, Remove the battery: step 20, image 1 of 3 AirPods Max Charging Port Replacement, Remove the battery: step 20, image 2 of 3 AirPods Max Charging Port Replacement, Remove the battery: step 20, image 3 of 3
    • Slide the battery cells out of their recesses one at a time and remove them.
    • If either of the battery cells are swollen, take appropriate precautions.
    Ask FixBot
  21. AirPods Max Charging Port Replacement, Remove the power board connector cover: step 21, image 1 of 2 AirPods Max Charging Port Replacement, Remove the power board connector cover: step 21, image 2 of 2
    • Use a Torx Plus 1IP screwdriver to remove the two 1.7 mm‑long screws securing the power board connectors cover.
    Ask FixBot
  22. AirPods Max Charging Port Replacement: step 22, image 1 of 2 AirPods Max Charging Port Replacement: step 22, image 2 of 2
    • The cover may be lightly secured with adhesive.
    Ask FixBot
  23. AirPods Max Charging Port Replacement, Disconnect the power board: step 23, image 1 of 3 AirPods Max Charging Port Replacement, Disconnect the power board: step 23, image 2 of 3 AirPods Max Charging Port Replacement, Disconnect the power board: step 23, image 3 of 3
    • Use a spudger to pry up and disconnect the three press connectors on the power board.
    Ask FixBot
  24. AirPods Max Charging Port Replacement, Remove the power board screws: step 24, image 1 of 3 AirPods Max Charging Port Replacement, Remove the power board screws: step 24, image 2 of 3 AirPods Max Charging Port Replacement, Remove the power board screws: step 24, image 3 of 3
    • Use a Torx Plus 3IP screwdriver to remove the two 5.7 mm‑long screws securing the power board.
    • Make sure not to lose the small rubber gasket on the screws.
    Ask FixBot
  25. AirPods Max Charging Port Replacement, Reposition the power board: step 25, image 1 of 3 AirPods Max Charging Port Replacement, Reposition the power board: step 25, image 2 of 3 AirPods Max Charging Port Replacement, Reposition the power board: step 25, image 3 of 3
    • Be careful not to grip any of the small, surface-mounted components on the power board.
    • Slowly pull the power board out of its recess and flip it over the side of the ear cup, giving you access to the connector on the underside.
    • Make sure the cables that connect to the board don't get snagged.
    Ask FixBot
  26. AirPods Max Charging Port Replacement, Disconnect the power board: step 26, image 1 of 3 AirPods Max Charging Port Replacement, Disconnect the power board: step 26, image 2 of 3 AirPods Max Charging Port Replacement, Disconnect the power board: step 26, image 3 of 3
    • Disconnecting the power board cable is tricky and may take a few tries. Don't try to disconnect it by pulling on the cable, or you may cause damage.
    • Use the point of a spudger to press on alternating sides of the sliding connector tabs to "walk" it out of the socket.
    Ask FixBot
  27. AirPods Max Charging Port Replacement, Remove the power board: step 27, image 1 of 1
    • Remove the power board.
    Ask FixBot
  28. AirPods Max Charging Port Replacement, Detach the mic cable: step 28, image 1 of 2 AirPods Max Charging Port Replacement, Detach the mic cable: step 28, image 2 of 2
    • Use tweezers or your fingers to gently lift the mic cable off the top of the charging port.
    • Be careful not to crease or tear the cable.
    Ask FixBot
  29. AirPods Max Charging Port Replacement, Remove the charging port screws: step 29, image 1 of 3 AirPods Max Charging Port Replacement, Remove the charging port screws: step 29, image 2 of 3 AirPods Max Charging Port Replacement, Remove the charging port screws: step 29, image 3 of 3
    iFixit Precision 4 mm Screwdriver Bit
    $2.99
    Buy
    • Given the location of the screws, getting a proper fit with your driver is difficult—and these screws strip easily. A flexible extension works well for the upper screws. You may need to put your bit in a nut driver of the corresponding size to remove the lower screws.
    • Remove the four screws securing the charging port:
    • Two 3.7 mm‑long Torx Plus 3IP screws
    • Two 2.2 mm‑long Torx Plus 1IP screws
    Ask FixBot
  30. AirPods Max Charging Port Replacement, Remove the charging port: step 30, image 1 of 2 AirPods Max Charging Port Replacement, Remove the charging port: step 30, image 2 of 2
    • While holding the microphone cable out of the way, use tweezers to slide the charging port out of its recess and remove it.
    • If you're having trouble, it may be easier to hold the ear cup at an angle while removing the port.
    Ask FixBot
  31. AirPods Max Charging Port Replacement, Disassembly complete: step 31, image 1 of 1
    • Congratulations on completing disassembly! The remaining steps will show how to reassemble your AirPods Max.
    Ask FixBot
  32. AirPods Max Charging Port Replacement, Connect a charging cable: step 32, image 1 of 2 AirPods Max Charging Port Replacement, Connect a charging cable: step 32, image 2 of 2
    • Plugging in a charging cable helps ensure the port is properly aligned, as well as making it significantly easier to install the screws. Make sure the cable is not plugged into a power source.
    • Align the charging port with its screw holes and plug in a charging cable, making sure the microphone cable goes over the top of the port.
    Ask FixBot
  33. AirPods Max Charging Port Replacement, Install the charging port screws: step 33, image 1 of 3 AirPods Max Charging Port Replacement, Install the charging port screws: step 33, image 2 of 3 AirPods Max Charging Port Replacement, Install the charging port screws: step 33, image 3 of 3
    Magnetizer / Demagnetizer
    $8.99
    Buy
    • Install the four screws securing the charging port:
    • If you're using the nut driver method, you may need to use a magnetizer to get the screws to stick to the bit.
    Ask FixBot
  34. AirPods Max Charging Port Replacement, Unplug the charging cable: step 34, image 1 of 1
    • Unplug the charging cable.
    Ask FixBot
  35. AirPods Max Charging Port Replacement, Secure the microphone cable: step 35, image 1 of 3 AirPods Max Charging Port Replacement, Secure the microphone cable: step 35, image 2 of 3 AirPods Max Charging Port Replacement, Secure the microphone cable: step 35, image 3 of 3
    • Flip the microphone cable down over the top of the charging port so the alignment peg goes through its cutout.
    Ask FixBot
  36. AirPods Max Charging Port Replacement: step 36, image 1 of 2 AirPods Max Charging Port Replacement: step 36, image 2 of 2
    • Use the point of a spudger to gently press the microphone cable onto the port, securing it with the leftover adhesive on the cable.
    Ask FixBot
  37. AirPods Max Charging Port Replacement, Connect the power board cable: step 37, image 1 of 2 AirPods Max Charging Port Replacement, Connect the power board cable: step 37, image 2 of 2
    • Use the point of a spudger to push on alternating sides of the copper cable's connector until it slides fully into the socket on the underside of the power board.
    • Don't grip the cable and push it into the socket—you'll likely damage the cable.
    • The connector should slide in fairly easily when oriented correctly. If it doesn't, flip the connector over and try again.
    Ask FixBot
  38. AirPods Max Charging Port Replacement, Put the power board in place: step 38, image 1 of 3 AirPods Max Charging Port Replacement, Put the power board in place: step 38, image 2 of 3 AirPods Max Charging Port Replacement, Put the power board in place: step 38, image 3 of 3
    • Flip the power board over and slide it into its recess, making sure the three cables that connect to the charging port don't get stuck underneath.
    Ask FixBot
  39. AirPods Max Charging Port Replacement, Before installing the power board screws: step 39, image 1 of 3 AirPods Max Charging Port Replacement, Before installing the power board screws: step 39, image 2 of 3 AirPods Max Charging Port Replacement, Before installing the power board screws: step 39, image 3 of 3
    • Before installing the power board screws:
    • Make sure the three cables are oriented so they can connect to the board.
    • The gold speaker contacts should be sitting in their small groove.
    • Check that each screw has its rubber gasket installed.
    Ask FixBot
  40. AirPods Max Charging Port Replacement, Install the power board screws: step 40, image 1 of 2 AirPods Max Charging Port Replacement, Install the power board screws: step 40, image 2 of 2
    • Use a Torx Plus 3IP screwdriver to install the two 5.7 mm‑long screws securing the power board.
    Ask FixBot
  41. AirPods Max Charging Port Replacement, Connect the power board cables: step 41, image 1 of 3 AirPods Max Charging Port Replacement, Connect the power board cables: step 41, image 2 of 3 AirPods Max Charging Port Replacement, Connect the power board cables: step 41, image 3 of 3
    • Use your finger to press down and reconnect the three power board press connectors.
    Ask FixBot
  42. AirPods Max Charging Port Replacement, Install the cable cover: step 42, image 1 of 2 AirPods Max Charging Port Replacement, Install the cable cover: step 42, image 2 of 2
    • Put the connector cover into place on the center of the power board.
    Ask FixBot
  43. AirPods Max Charging Port Replacement: step 43, image 1 of 2 AirPods Max Charging Port Replacement: step 43, image 2 of 2
    • Use a Torx Plus 1IP screwdriver to install the two 1.7 mm‑long screws securing the connector cover.
    Ask FixBot
  44. AirPods Max Charging Port Replacement, Slide the battery into place: step 44, image 1 of 3 AirPods Max Charging Port Replacement, Slide the battery into place: step 44, image 2 of 3 AirPods Max Charging Port Replacement, Slide the battery into place: step 44, image 3 of 3
    • With the exposed sides of the battery cells facing down, slide the battery cable under the lip of the ear cup so it sits on top of the charging port.
    • Place both battery cells into their recesses.
    Ask FixBot
  45. AirPods Max Charging Port Replacement, Install the battery screws: step 45, image 1 of 2 AirPods Max Charging Port Replacement, Install the battery screws: step 45, image 2 of 2
    • Use a Torx Plus 3IP screwdriver to install the three screws securing the battery cells:
    Ask FixBot
  46. AirPods Max Charging Port Replacement: step 46, image 1 of 3 AirPods Max Charging Port Replacement: step 46, image 2 of 3 AirPods Max Charging Port Replacement: step 46, image 3 of 3
    • Use a Torx Plus 5IP screwdriver to install the two screws securing the sides of the battery cells.
    • You may need to use tweezers to slide the screws into their holes.
    Ask FixBot
  47. AirPods Max Charging Port Replacement, Connect the battery: step 47, image 1 of 1
    • Use a spudger or your fingers to press down and connect the battery press connector.
    Ask FixBot
  48. AirPods Max Charging Port Replacement, Install the battery cable cover: step 48, image 1 of 3 AirPods Max Charging Port Replacement, Install the battery cable cover: step 48, image 2 of 3 AirPods Max Charging Port Replacement, Install the battery cable cover: step 48, image 3 of 3
    • Slide the battery connector cover's two tabs into their slots and lay the cover in place.
    Ask FixBot
  49. AirPods Max Charging Port Replacement: step 49, image 1 of 2 AirPods Max Charging Port Replacement: step 49, image 2 of 2
    • Install the two connector cover screws:
    Ask FixBot
  50. AirPods Max Charging Port Replacement, Lay the speaker driver in place: step 50, image 1 of 3 AirPods Max Charging Port Replacement, Lay the speaker driver in place: step 50, image 2 of 3 AirPods Max Charging Port Replacement, Lay the speaker driver in place: step 50, image 3 of 3
    • Gently lay the speaker driver into place, making sure the side with gold connector pins lines up with their contacts in the shell.
    Ask FixBot
  51. AirPods Max Charging Port Replacement, Install the speaker driver screws: step 51, image 1 of 3 AirPods Max Charging Port Replacement, Install the speaker driver screws: step 51, image 2 of 3 AirPods Max Charging Port Replacement, Install the speaker driver screws: step 51, image 3 of 3
    • Grip the screws with tweezers while installing them so they don't snap onto the speaker.
    • Use a Torx Plus 3IP screwdriver to install three speaker driver screws:
    • Install the 5.1 mm‑long standoff screw using a small flathead or Torq-Set 6 screwdriver.
    Ask FixBot
  52. AirPods Max Charging Port Replacement, Replace the speaker housing adhesive: step 52, image 1 of 3 AirPods Max Charging Port Replacement, Replace the speaker housing adhesive: step 52, image 2 of 3 AirPods Max Charging Port Replacement, Replace the speaker housing adhesive: step 52, image 3 of 3
    • Before installing the speaker housing, check the condition of its adhesive—it will be on the underside of the housing, on the metal lip of the ear cup, or on both.
    • Use tweezers and scissors to remove any sections of bunched-up or overlapping adhesive that would prevent the housing from sitting perfectly flat.
    • Try to remove as little adhesive as possible. If all the adhesive looks fine, you can skip this step.
    • Apply thin, double-sided adhesive where you removed the original, using short sections to help match the curve of the lip.
    • Don't remove the top adhesive liners yet—the adhesive should not be exposed.
    • Make sure not to double up on any sections (i.e. don't apply adhesive on the ear cup if it's already on the corresponding spot on the housing).
    Ask FixBot
  53. AirPods Max Charging Port Replacement, Connect the speaker housing: step 53, image 1 of 2 AirPods Max Charging Port Replacement, Connect the speaker housing: step 53, image 2 of 2
    • Hold the speaker housing up and use your finger to press down and reconnect its press connector.
    Ask FixBot
  54. AirPods Max Charging Port Replacement, Install the housing cable cover: step 54, image 1 of 2 AirPods Max Charging Port Replacement, Install the housing cable cover: step 54, image 2 of 2
    • Slide the tab on the connector cover into its slot and lay the cover down.
    Ask FixBot
  55. AirPods Max Charging Port Replacement: step 55, image 1 of 2 AirPods Max Charging Port Replacement: step 55, image 2 of 2
    • Use a Torx Plus 1IP screwdriver to install the 1.7 mm‑long screw securing the speaker housing cable cover.
    Ask FixBot
  56. AirPods Max Charging Port Replacement, Secure the speaker housing: step 56, image 1 of 3 AirPods Max Charging Port Replacement, Secure the speaker housing: step 56, image 2 of 3 AirPods Max Charging Port Replacement, Secure the speaker housing: step 56, image 3 of 3
    • If you installed replacement adhesive, remove any liners to expose the adhesive.
    • Flip the speaker housing into the cup and press it into place around the perimeter.
    • Don't press on the center of the housing or you may damage the grille and/or speaker underneath.
    Ask FixBot
  57. AirPods Max Charging Port Replacement, Turn the housing screws to the locked position: step 57, image 1 of 2 AirPods Max Charging Port Replacement, Turn the housing screws to the locked position: step 57, image 2 of 2
    • Use a P5 pentalobe screwdriver to turn the four speaker housing screws to the locked position:
    • Turn the top left and bottom right screws clockwise.
    • Turn the top right and bottom left screws counterclockwise.
    Ask FixBot
  58. AirPods Max Charging Port Replacement, Install the right ear cup: step 58, image 1 of 3 AirPods Max Charging Port Replacement, Install the right ear cup: step 58, image 2 of 3 AirPods Max Charging Port Replacement, Install the right ear cup: step 58, image 3 of 3
    • The headband and ear cup should be oriented in the "closed" position (how they would be when stored in a case) when installing them.
    • Hold the ear cup steady with one hand, and use your free hand to firmly push the headband connector into its slot, twisting it slightly—it should click into place.
    • The connector should slide in easily. If it's not, make sure you're installing the ear cup on the correct side.
    Ask FixBot
  59. AirPods Max Charging Port Replacement, Install the right earpad: step 59, image 1 of 2 AirPods Max Charging Port Replacement, Install the right earpad: step 59, image 2 of 2
    • Place the earpad into its cup—it should "snap" into place.
    Ask FixBot
Congratulations on completing your repair!
Spencer Day
196,166 Reputation
1,243 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 47
Past 30 Days: 246
All Time: 828
