AirPods Charging Case Disassembly
  1. AirPods Charging Case Disassembly, AirPods Charging Case Disassembly: step 1, image 1 of 3 AirPods Charging Case Disassembly, AirPods Charging Case Disassembly: step 1, image 2 of 3 AirPods Charging Case Disassembly, AirPods Charging Case Disassembly: step 1, image 3 of 3
    • This is a charging case for AirPods, which is currently waterlogged. I will try to take it apart and test the internals for water damage.
  2. AirPods Charging Case Disassembly: step 2, image 1 of 3 AirPods Charging Case Disassembly: step 2, image 2 of 3 AirPods Charging Case Disassembly: step 2, image 3 of 3
    • Find a pair of tweezer, and then divide it into two halves to create a spudger. Then grind it with a grinder to the size required to be reasonably long and thick, ready for the next step of disassembly! Or buy one from ifixit
  3. AirPods Charging Case Disassembly: step 3, image 1 of 3 AirPods Charging Case Disassembly: step 3, image 2 of 3 AirPods Charging Case Disassembly: step 3, image 3 of 3
    • Using a scalpel, insert the inside and outside to slide left and right so that the connection parts of the charging case are completely loose, and then lift a space and insert a tool as a lever.
    To separate this part, I took a pair of needle-nose plyers and stick the ends down towards the columns where the base of the air pods sit. Clamp the plyers together and slowly extract, and it will come out scratch free. Just be sure to use a cloth in between the teeth of the plyers to avoid scratching the plastic when you squeeze down.
    Also note to not pull it out completely because you will rip other components apart.
    Joe Krajicek - Reply
  4. AirPods Charging Case Disassembly: step 4, image 1 of 3 AirPods Charging Case Disassembly: step 4, image 2 of 3 AirPods Charging Case Disassembly: step 4, image 3 of 3
    • Use a polished metal lever to loosen it further, then fix it with a vise grip, tighten it slowly to deform the load and outer shell, and then loosen with the tool. (Remember to secure the AirPods on both sides of the shell before attaching it. Prevent the press from leaving traces on the outer casing.)
  5. AirPods Charging Case Disassembly: step 5, image 1 of 3 AirPods Charging Case Disassembly: step 5, image 2 of 3 AirPods Charging Case Disassembly: step 5, image 3 of 3
    • After loosening, use a metal lever, pull both sides at the same time, then pay attention to the cable to pull out the internal base and finally heat with a hot air gun to remove the stainless steel internal fixed iron ring.
    No way it is so easy as shown here. Sides are glued as well as the front, plus the force to pull it out needs to be against the outer shell, which causes a lot of stress to this part of the plastic. What is the thickness of these tools which you slide on each side?
    redex7 - Reply
  6. AirPods Charging Case Disassembly: step 6, image 1 of 3 AirPods Charging Case Disassembly: step 6, image 2 of 3 AirPods Charging Case Disassembly: step 6, image 3 of 3
    • After removing the stainless steel fixed iron ring, then use a heat gun to heat, the indicator light and the charging contact base of the AirPods.
  7. AirPods Charging Case Disassembly: step 7, image 1 of 3 AirPods Charging Case Disassembly: step 7, image 2 of 3 AirPods Charging Case Disassembly: step 7, image 3 of 3
    • After heating the base of the contact, use a scalpel to open it. The adhering parts become loosened further so you can finally remove them from the bottom.
  8. AirPods Charging Case Disassembly: step 8, image 1 of 3 AirPods Charging Case Disassembly: step 8, image 2 of 3 AirPods Charging Case Disassembly: step 8, image 3 of 3
    • Heat with a hot air gun, cover the metal connection parts, the temperature here is slightly higher, about 90 to more than 100 degrees, after heating for 20 seconds.
  9. AirPods Charging Case Disassembly: step 9, image 1 of 3 AirPods Charging Case Disassembly: step 9, image 2 of 3 AirPods Charging Case Disassembly: step 9, image 3 of 3
    • After continuing to heat with a heat gun, loosen the battery with a lever, loosen the push button on the base of the fixed connection cable and remove the battery.
  10. AirPods Charging Case Disassembly: step 10, image 1 of 2 AirPods Charging Case Disassembly: step 10, image 2 of 2
    • After removing the battery, remove the protective plate position, clean it with internal wash water and recharge it with an adjustable DC power supply.
  11. AirPods Charging Case Disassembly: step 11, image 1 of 3 AirPods Charging Case Disassembly: step 11, image 2 of 3 AirPods Charging Case Disassembly: step 11, image 3 of 3
    • Use the scalpel to slide the inner frame and fixed frame to the left and right to loosen the attachment parts. You can use the heating method to slide while heating, and then use the special metal lever polished before the hammer to force down.
  12. AirPods Charging Case Disassembly: step 12, image 1 of 3 AirPods Charging Case Disassembly: step 12, image 2 of 3 AirPods Charging Case Disassembly: step 12, image 3 of 3
    • Continue repeating the previous operation until it is completely loose, and finally remove the internal support.
  13. AirPods Charging Case Disassembly: step 13, image 1 of 3 AirPods Charging Case Disassembly: step 13, image 2 of 3 AirPods Charging Case Disassembly: step 13, image 3 of 3
    • After complete removal, remove it with a screwdriver and connect the cable at the base of the headset to the cable that is loaded with the lightning interface below.
  14. AirPods Charging Case Disassembly: step 14, image 1 of 3 AirPods Charging Case Disassembly: step 14, image 2 of 3 AirPods Charging Case Disassembly: step 14, image 3 of 3
    • After complete removal, a screwdriver is included and the cable is connected to the base of the headset to the cable that is loaded with the lightning interface below.
  15. AirPods Charging Case Disassembly: step 15, image 1 of 3 AirPods Charging Case Disassembly: step 15, image 2 of 3 AirPods Charging Case Disassembly: step 15, image 3 of 3
    • After pulling away the circuit board, you can see that some of its components are very corroded. After all, the case was in the water for a long time.
  16. AirPods Charging Case Disassembly: step 16, image 1 of 3 AirPods Charging Case Disassembly: step 16, image 2 of 3 AirPods Charging Case Disassembly: step 16, image 3 of 3
    • First I use the ultrasonic cleaner with PCB cleaning liquid to try and save the circuit board.
  17. AirPods Charging Case Disassembly: step 17, image 1 of 3 AirPods Charging Case Disassembly: step 17, image 2 of 3 AirPods Charging Case Disassembly: step 17, image 3 of 3
    • After the cleaning, don't worry about the lithium battery just yet. Connect the charger to the circuit board and see if the charging indicator turns on.
    • Looks like this circuit board still needs work. The light isn't turning on. Check that the current is 6 mA. The PMIC is often the problem, as it is one of the more fragile components of the board.
    • Remove any damaged components, find their identical replacements and replace them on the board. Only attempt this step if you have experience with microsoldering. If not, you can consult my recommendations at the end of the disassembly.
    这里针对专业人士,普通用户的话请看我的建议在文章最后~~~
    在文章最后没有找到啊
    wang - Reply
  18. AirPods Charging Case Disassembly: step 18, image 1 of 3 AirPods Charging Case Disassembly: step 18, image 2 of 3 AirPods Charging Case Disassembly: step 18, image 3 of 3
    • I almost forgot the button that iFixit didn't disassemble completely!
    • What is the secret of this button? To be sure, I take a peek. On the inside, it looks similar to the iPhone 5 and iPhone SE home buttons.
  19. AirPods Charging Case Disassembly: step 19, image 1 of 2 AirPods Charging Case Disassembly: step 19, image 2 of 2
    • In summary, this disassembly of an AirPods case is directed primarily to normal users who have waterlogged AirPods cases. You can attempt to dismantle them with this method, as best you can.
    • After the cleaning, you can use a hair dryer to heat and dry the circuit board. If functionality is restored, you can use B7000 glue to put the case back together. Hopefully this helps everyone!
    • Finally, I'd like to ask the teardown team at iFixit: Can you change the repairability score of the AirPods from a 0 now? (^_^)
    Nice disassembly tutorial - reasonable enough! Now can you assemble it?
    patrick.babcock - Reply
    What’s the power voltage transmission from the case to the AirPods when the case is charging the AirPods?
    Dj Smart - Reply
    Acabo de comprar unos clon pero al abrirlos no encienden, al revisar el ticket dice que no tienen garantía por estar en rebaja, alguna sugerencia? Se podrán reparar? Los que muestras son diferentes para abrirlos por ser originales?
    Carla - Reply
Finish Line
51 other people completed this guide.
Special thanks to these translators:
zh en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
deng lei
3,013 Reputation
2 Guides authored
13 Comments
66666,我看拆的過程中有一些部分損毀,請問還能裝回去麼?
zhewen - Reply
,部分损伤只是内部的根本不影响,肯定可以装回的,用胶粘好完全看不出来,不影响使用,除非你打开盖子仔细看边上的划痕,但立刻用抛光砂纸打磨去掉
Deng lei -
我去 厉害的攻略! 我的airpod进水之后就搁置了。 准备试一下。请问如何控制热枪的温度?
Sheng Qu - Reply
短时间内大概90-110度今天你自己感觉了手抹上很烫手且外壳未发生形变即可
deng lei -
So, just buy new AirPods then?
Justin Winchester - Reply
Haha thats exactly what this article tought me too :D
Moritz Scheidenberger -
Sounds about right… ;-)
Way to much work.
iZPhoneMan -
Why was it English to some language?!
kajussls121 - Reply
Bonjours, ou trouver des pièces détaché pour airpod ?
kaius - Reply
still looks like a “0” to me
Studio Harrison - Reply
thinks that helped me out it works know.
Jeremy Gregory - Reply
Thank you for this breakdown. A common issue is that the conductive metal at the bottom of the tube loses its springiness. This has resulted in one of my earbuds not charging. Otherwise, they've worked great. I plan to use these steps to hopefully repair it.
JohnJ - Reply
mis audífonos son clon pero igual la info me ayudó á abrirlos
Leonardo Mendoza Chavez - Reply
Past 24 Hours: 128
Past 7 Days: 914
Past 30 Days: 4,308
All Time: 291,345
