You're viewing a previously published version of this guide.  View latest version
Older Newer
Introduction
The purpose of this guide is to open the Smash Bot Robot to reach internal parts.
  1. Using a Phillip #0 screwdriver to remove the eight 8 mm screws. Using a Phillip #0 screwdriver to remove the eight 8 mm screws.
    • Using a Phillip #0 screwdriver to remove the eight 8 mm screws.
  2. Remove the upper armor of the Smash Bot. Remove the upper armor of the Smash Bot.
    • Remove the upper armor of the Smash Bot.
  3. Hold the upper body and slide out the bottom half of the Smash Bot.
    • Hold the upper body and slide out the bottom half of the Smash Bot.
    • The motor extends from the lower-body into the upper-body. Be careful to not damage the motor.
  4. Peel back the four decal stickers that hold the front and back of the bot together.
    • Peel back the four decal stickers that hold the front and back of the bot together.
  5. Use the plastic opening tool to pry the  front and back of the lower body apart. Carefully remove the back of the bot from the front.
    • Use the plastic opening tool to pry the front and back of the lower body apart.
    • Carefully remove the back of the bot from the front.
Nick Ciulla
240 Reputation
2 Guides authored
IUPUI, Team 1-1, Baechle Spring 2016 Member of IUPUI, Team 1-1, Baechle Spring 2016
IUPUI-BAECHLE-S16S1G1
4 Members
7 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 40
