Shop the Holiday Gift Guide
Afloia Fillo Air Filter Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
28
Past 30 Days:
113
All Time:
1,154
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Maintaining clean and healthy air in your home is essential to your well-being, and your Afloia Fillo air purifier plays a role in making this happening. To ensure it's always working at its best, it is necessary to replace the air filter regularly. This guide will show you simple steps to replace the air filter in your Afloia Fillo, ensuring that your device continues to provide you with the freshest air possible. Whether you're a first-time user or just need a refresher, this step-by-step guide will make the process quick and easy!
Before using this guide, you will need to have your replacement filter ready to go.
    1. Afloia Fillo Air Filter Replacement, Air Filter: step 1, image 1 of 2 Afloia Fillo Air Filter Replacement, Air Filter: step 1, image 2 of 2
      • Turn off and unplug the air purifier.
      Ask FixBot
    2. Afloia Fillo Air Filter Replacement: step 2, image 1 of 2 Afloia Fillo Air Filter Replacement: step 2, image 2 of 2
      • Place the air purifier on its side.
      • Unscrew the base of the purifier to uncover the filter.
      Ask FixBot
    3. Afloia Fillo Air Filter Replacement: step 3, image 1 of 2 Afloia Fillo Air Filter Replacement: step 3, image 2 of 2
      • Take out the old filter.
      • The old filter can be thrown in the garbage.
      Ask FixBot
    4. Afloia Fillo Air Filter Replacement: step 4, image 1 of 3 Afloia Fillo Air Filter Replacement: step 4, image 2 of 3 Afloia Fillo Air Filter Replacement: step 4, image 3 of 3
      • Remove the packaging of the new filter and place it into the purifier.
      Ask FixBot
    5. Afloia Fillo Air Filter Replacement: step 5, image 1 of 3 Afloia Fillo Air Filter Replacement: step 5, image 2 of 3 Afloia Fillo Air Filter Replacement: step 5, image 3 of 3
      • Screw the base back on.
      • When putting the base on, make sure the arrow on cover matches the open arrow on the purifier, then turn the cover until the base arrow lines up with the close arrow.
      Ask FixBot
    6. Afloia Fillo Air Filter Replacement: step 6, image 1 of 1
      • Plug in the purifier and turn it on.
      • Press and hold the power button for 7 seconds to reset the air purifier and begin using the new filter.
      • Once the green light comes on, your purifier is ready to go.
      Ask FixBot
Finish Line
Author
with
Ayotunde Dada
291 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 28
Past 30 Days: 113
All Time: 1,154
