Advanced Gear Tape Techniques
Views: 1.3K
View statistics:
Past 24 Hours:
6
Past 7 Days:
75
Past 30 Days:
217
All Time:
1,349
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Moderate
Patagonia
Patagonia and iFixit are celebrating the stories we wear by collaborating to provide guides for Patagonia's most popular apparel repairs.
Introduction
Go to step 1 ↓
Adhesive patching is a quick and easy way to repair gear in the field.
If you're new to gear tape, start with Patch an Insulated Jacket with Repair Tape for the basics. This guide goes further, covering advanced techniques, practical tips, and creative solutions for using adhesive patches in a variety of situations.
Tenacious Tape® and other gear tapes will only stick to synthetic, non-stretch fabrics such as Down Sweaters™, Nano Puff® Jackets, rain shells and ski gear. They will not adhere to natural fabrics (like denim or cotton), high-stretch fabrics, or anything with a high pile like fleece.
Tenacious Tape® can be acquired here, on the Gear Aid website, or by contacting Patagonia Customer Service.
Alternatively, Patagonia products can be taken to a local retail store for repair evaluation or sent in to Patagonia through their mail-in repair service.
Let's get fixing!
Return to the Patagonia Care & Repair homepage.
Parts
Tools
    1. Advanced Gear Tape Techniques, Patch Size: step 1, image 1 of 3 Advanced Gear Tape Techniques, Patch Size: step 1, image 2 of 3 Advanced Gear Tape Techniques, Patch Size: step 1, image 3 of 3
      • The patch should extend at least ¼–½in (~6–13 mm) beyond the hole on all sides. This ensures the tape has a strong grip on undamaged fabric.
      • Avoid tiny patches. Anything smaller than ½ in (~13 mm) may not adhere effectively.
      • Pre-Cut Patches
      • You can cut your own shapes or use pre-cut patches.
      • Pre-cut patches have been die or laser cut, giving them clean and consistent edges.
      Ask FixBot
    2. Advanced Gear Tape Techniques, Number of Patches: step 2, image 1 of 3 Advanced Gear Tape Techniques, Number of Patches: step 2, image 2 of 3 Advanced Gear Tape Techniques, Number of Patches: step 2, image 3 of 3
      • If the holes are more than 2 in (~5 cm) apart, cover them with two patches.
      • If multiple holes are close together, you can use one large patch or overlap smaller ones.
      • Overlapping smaller patches is especially useful for irregular-shaped damage such as L-shaped tears.
      Ask FixBot
    3. Advanced Gear Tape Techniques, Escaping Insulation: step 3, image 1 of 3 Advanced Gear Tape Techniques, Escaping Insulation: step 3, image 2 of 3 Advanced Gear Tape Techniques, Escaping Insulation: step 3, image 3 of 3
      • If down or synthetic fill is escaping through the hole, use your fingers or the back of a pen to gently push it back inside before patching.
      • Saving insulation is critical! It keeps your gear warm and functional.
      • If you don't have Tenacious Tape® or another professional gear tape when your item tears, use whatever is available.
      Ask FixBot
    4. Advanced Gear Tape Techniques, Shaping Patch to Design: step 4, image 1 of 3 Advanced Gear Tape Techniques, Shaping Patch to Design: step 4, image 2 of 3 Advanced Gear Tape Techniques, Shaping Patch to Design: step 4, image 3 of 3
      • Whenever possible, choose or cut a patch that follows the garment’s design lines. This improves the look of the repair and helps avoid patching over seams.
      • While patching over seams is sometimes unavoidable, positioning patches away from seams when possible improves adhesion and makes future repairs easier.
      • Consider shapes that align with:
      • Diamond baffles
      • Curved seams
      • Sharp angular fabric pieces
      Ask FixBot
    5. Advanced Gear Tape Techniques, Long Slices: step 5, image 1 of 3 Advanced Gear Tape Techniques, Long Slices: step 5, image 2 of 3 Advanced Gear Tape Techniques, Long Slices: step 5, image 3 of 3
      • Patching large slits can be tricky, here’s how to handle them:
      • Arrange the fabric first: Lay the damaged area flat in the position you want before applying gear tape. Use pattern weights to hold it in place if needed.
      • Tuck insulation inside: Make sure feathers or synthetic fill are pushed back into the hole.
      • Peel patch carefully: Don’t peel the entire backing at once. Start with one edge, place it down, then peel and apply gradually.
      • Apply slowly: Smooth as you go to avoid wrinkles and ensure strong adhesion.
      Ask FixBot
    6. Advanced Gear Tape Techniques, Sandwich Patching: step 6, image 1 of 3 Advanced Gear Tape Techniques, Sandwich Patching: step 6, image 2 of 3 Advanced Gear Tape Techniques, Sandwich Patching: step 6, image 3 of 3
      • For unlined or uninsulated items where the hole goes all the way through, patch both sides for a strong repair:
      • Cut two patches that each extend at least ½" (~13 mm) beyond the damaged area on all sides.
      • Apply one patch to the inside and one to the outside.
      • If the item is semi-transparent, make the outer patch at least ¼" (~6 mm) larger than the inside patch on all sides. Align them so the inside patch isn’t visible from the outside.
      Ask FixBot
    7. Advanced Gear Tape Techniques, Underarm Seams: step 7, image 1 of 3 Advanced Gear Tape Techniques, Underarm Seams: step 7, image 2 of 3 Advanced Gear Tape Techniques, Underarm Seams: step 7, image 3 of 3
      • Small holes along the underarm seams are common due to abrasion from arm movement. Here’s how to repair them:
      • Cover multiple holes at once: Cut strips of gear tape up to 4 in (~10 cm) long to span a worn section.
      • Seam overlap is okay: It’s fine for the tape to cross over the seam, its unavoidable in this repair!
      Ask FixBot
    8. Advanced Gear Tape Techniques, Burned Areas: step 8, image 1 of 3 Advanced Gear Tape Techniques, Burned Areas: step 8, image 2 of 3 Advanced Gear Tape Techniques, Burned Areas: step 8, image 3 of 3
      • Burned fabric or insulation often has a hard, melted edge.
      • Trim away any hardened or melted material before applying the patch.
      • If a large section is removed, see Step 10 for how to replace missing fabric before patching.
      Ask FixBot
    9. Advanced Gear Tape Techniques, Threadbare Areas: step 9, image 1 of 3 Advanced Gear Tape Techniques, Threadbare Areas: step 9, image 2 of 3 Advanced Gear Tape Techniques, Threadbare Areas: step 9, image 3 of 3
      • The fabric around a tear or hole may be weakened, worn, or abraded. Without reinforcement, these threadbare zones are likely to tear soon.
      • To check for and repair threadbare spots:
      • Light test: Hold the item up to the light. If light passes through the area more easily than the rest of the fabric, it’s threadbare.
      • Extend the patch: Treat threadbare fabric as damage. Cut a patch that extends at least ¼" in (~6 mm) beyond the entire threadbare zone on all sides.
      Ask FixBot
    10. Advanced Gear Tape Techniques, Missing Fabric: step 10, image 1 of 3 Advanced Gear Tape Techniques, Missing Fabric: step 10, image 2 of 3 Advanced Gear Tape Techniques, Missing Fabric: step 10, image 3 of 3
      • Gear tape needs something solid to stick to. If fabric is missing, the tape will adhere to feathers or inner layers—reducing warmth. To fix this:
      • Cut a piece of similar fabric that is slightly larger than the open area.
      • Fabric type matters more than color, it'll be covered by the tape!
      • Use tweezers to Insert the fabric into the hole so it sits on top of the insulation but behind the damaged fabric, completely covering the gap.
      • Apply gear tape over the hole.
      • If the item isn’t insulated and fabric is missing, see Step 6 on Sandwich Patching.
      Ask FixBot
    11. Advanced Gear Tape Techniques, Wrap Around Patches: step 11, image 1 of 3 Advanced Gear Tape Techniques, Wrap Around Patches: step 11, image 2 of 3 Advanced Gear Tape Techniques, Wrap Around Patches: step 11, image 3 of 3
      • When there is damage within ⅛ in (~3 mm) of an edge, use an edge wrap technique to ensure full coverage and durability.
      • Wrap the patch snugly around the edge without pinching or folding.
      • In the pictured repair, a piece of Tenacious Tape® is wrapped around the placket of an Nano Puff®. This technique is also ideal for cuffs, hems, and collars (See Step 12).
      Ask FixBot
    12. Advanced Gear Tape Techniques, Wrap Around Patches: step 12, image 1 of 3 Advanced Gear Tape Techniques, Wrap Around Patches: step 12, image 2 of 3 Advanced Gear Tape Techniques, Wrap Around Patches: step 12, image 3 of 3
      • The same edge wrapping technique in the previous step also applies to damaged cuffs, hems and collars.
      • In the pictured repair, a piece of Tenacious Tape® is wrapped around the cuff of a Torrentshell® where the edge has frayed.
      Ask FixBot
    13. Advanced Gear Tape Techniques, Slit-to-Wrap Technique: step 13, image 1 of 3 Advanced Gear Tape Techniques, Slit-to-Wrap Technique: step 13, image 2 of 3 Advanced Gear Tape Techniques, Slit-to-Wrap Technique: step 13, image 3 of 3
      • When damage spans seam lines or crosses onto functional parts of the garment, a standard patch may interfere with functionality. To solve this:
      • Cut a patch: Shape the patch to match the area’s design lines (see Step 4).
      • Create a slit: Cut a slit in the patch to create tabs that can wrap smoothly around the damaged area without bunching.
      • This method works well for:
      • Corners of welt pockets or zipper vents
      • Areas that are curved or three-dimensional
      Ask FixBot
    14. Advanced Gear Tape Techniques, Applying Heat: step 14, image 1 of 3 Advanced Gear Tape Techniques, Applying Heat: step 14, image 2 of 3 Advanced Gear Tape Techniques, Applying Heat: step 14, image 3 of 3
      • Heat can improve adhesion, especially on heavily worn or soiled items where cleaning doesn’t remove all debris.
      • Lightly apply heat to the patched surface to quickly activate the glue at ~250° Fahrenheit / ~120° Celsius.
      • Use a medium-low or delicate setting on a home iron.
      • Or use a hair dryer on low-medium heat, blowing on the area for about 30 seconds.
      • Immediately after heating, apply firm pressure with a cold press for 15–30 seconds. An iron pattern weight or a metal cup works well.
      • Heat is not a substitute for curing! Tenacious Tape® still requires 24 hours to cure before the item can be laundered.
      Ask FixBot
    15. Advanced Gear Tape Techniques, Temporary Tapes: step 15, image 1 of 3 Advanced Gear Tape Techniques, Temporary Tapes: step 15, image 2 of 3 Advanced Gear Tape Techniques, Temporary Tapes: step 15, image 3 of 3
      • The most important thing is to prevent insulation from escaping and stop the tear from getting worse.
      • If you have a choice between tapes, pick one that won’t leave sticky residue, this makes it easier to replace with Tenacious Tape® later:
      • Avoid: Duct tape, gaffer tape, and Gorilla tape.
      • Clear office tape and colored masked tape are good for temporary hole coverage or marking damage, and they usually peel off cleanly.
      Ask FixBot
    16. Advanced Gear Tape Techniques, Removing Tape Adhesive: step 16, image 1 of 3 Advanced Gear Tape Techniques, Removing Tape Adhesive: step 16, image 2 of 3 Advanced Gear Tape Techniques, Removing Tape Adhesive: step 16, image 3 of 3
      • If professional gear tape wasn’t available in the field and another tape was used, remove it before applying Tenacious Tape®:
      • Remove the old tape slowly to avoid tearing or enlarging the damaged area.
      • Use rubbing alcohol to remove any adhesive residue:
      • Coat any residue with rubbing alcohol and let it sit.
      • Wipe away with cotton balls or a rag, then let the area dry completely.
      • The new tape won’t stick if any moisture remains, use heat from an iron (see Step 14) to speed drying.
      Ask FixBot
      • You can also use an adhesive eraser to remove tape residue:
      • Hold the area taught with one hand.
      • Use the other hand to rub the adhesive eraser over the sticky area in straight motions.
      • Be patient, as this can be tricky near holes. If feathers escape, stop and push them back in.
      • If the residue can't be removed, cut away the soiled fabric and apply a larger patch.
      Ask FixBot
    17. Advanced Gear Tape Techniques, Die Cut Tape Shapes: step 18, image 1 of 3 Advanced Gear Tape Techniques, Die Cut Tape Shapes: step 18, image 2 of 3 Advanced Gear Tape Techniques, Die Cut Tape Shapes: step 18, image 3 of 3
      • Precut shapes are generally more symmetrical and durable than hand-cut patches. If you want to create your own die-cut shapes:
      • Get the right tools: Metal dies are available online for public purchase.
      • Use a proper surface: Place the die on a self-healing cutting mat and strike with a rubber mallet.
      • Optional hot-cut method: For cleaner edges and increased durability, heat the edge of the die with a lighter before pressing.
      • Wear heat protective gloves!
      Ask FixBot
Finish Line
Alex Diaz-Kokaisl
251,129 Reputation
1,200 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 75
Past 30 Days: 217
All Time: 1,349
