Acer Spin 5 SP515-51GN-807G Battery Replacement
  1. Acer Spin 5 SP515-51GN-807G Battery Replacement, Back Cover: step 1, image 1 of 1
    • Remove the eleven 6.5 mm screws that secure the back case using a Phillips #1 screwdriver.
  2. Acer Spin 5 SP515-51GN-807G Battery Replacement: step 2, image 1 of 3 Acer Spin 5 SP515-51GN-807G Battery Replacement: step 2, image 2 of 3 Acer Spin 5 SP515-51GN-807G Battery Replacement: step 2, image 3 of 3
    • Use a plastic opening tool to gently pry open the back cover.
  3. Acer Spin 5 SP515-51GN-807G Battery Replacement: step 3, image 1 of 1
    • Gently remove the back cover from the device.
  4. Acer Spin 5 SP515-51GN-807G Battery Replacement, Battery: step 4, image 1 of 3 Acer Spin 5 SP515-51GN-807G Battery Replacement, Battery: step 4, image 2 of 3 Acer Spin 5 SP515-51GN-807G Battery Replacement, Battery: step 4, image 3 of 3
    • Remove the piece of black tape over the battery cable connector.
  5. Acer Spin 5 SP515-51GN-807G Battery Replacement: step 5, image 1 of 3 Acer Spin 5 SP515-51GN-807G Battery Replacement: step 5, image 2 of 3 Acer Spin 5 SP515-51GN-807G Battery Replacement: step 5, image 3 of 3
    • Remove the piece of black tape that covers the battery.
  6. Acer Spin 5 SP515-51GN-807G Battery Replacement: step 6, image 1 of 2 Acer Spin 5 SP515-51GN-807G Battery Replacement: step 6, image 2 of 2
    • Grip the battery cable on both sides with your fingertips and gently pull it away from the port.
    • If needed, use the plastic opening tool to remove the cord from its port.
  7. Acer Spin 5 SP515-51GN-807G Battery Replacement: step 7, image 1 of 3 Acer Spin 5 SP515-51GN-807G Battery Replacement: step 7, image 2 of 3 Acer Spin 5 SP515-51GN-807G Battery Replacement: step 7, image 3 of 3
    • Remove the two 3.5mm screws that secure the battery using a Phillips #00 screwdriver (PH00 bit).
  8. Acer Spin 5 SP515-51GN-807G Battery Replacement: step 8, image 1 of 2 Acer Spin 5 SP515-51GN-807G Battery Replacement: step 8, image 2 of 2
    • Carefully place your fingers under the plastic lip where the screws were removed.
    • Lift upwards to remove the battery.
    • Do not bend or puncture the lithium ion battery as it poses a fire hazard.
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 61
All Time: 1,345
