Introduction
We dismantled the Acer Iconia One 7 and found it to be extremely repairable with only 8 components.
  1. Acer Iconia One 7 Repairability Assessment, Acer Iconia One 7: step 1, image 1 of 3 Acer Iconia One 7 Repairability Assessment, Acer Iconia One 7: step 1, image 2 of 3 Acer Iconia One 7 Repairability Assessment, Acer Iconia One 7: step 1, image 3 of 3
    • Reference photos with packaging.
  2. Acer Iconia One 7 Repairability Assessment: step 2, image 1 of 1
    • Entry method is to remove the rear bathtub case, the seal is easy to break with opening tools.
    • The bathtub case is attached to the front display panel by soft plastic clips and without adhesive.
    • A spring connector connects the motherboard to the bathtub case so no need to worry about damaging fragile cables during removal.
  3. Acer Iconia One 7 Repairability Assessment: step 3, image 1 of 3 Acer Iconia One 7 Repairability Assessment: step 3, image 2 of 3 Acer Iconia One 7 Repairability Assessment: step 3, image 3 of 3
    • The battery cable runs short and requires a careful and precise wiggle to remove its connection from the motherboard.
    • Only two adhesive pull tabs secure the battery. This is preferred over adhesive which requires heat and prying to separate.
    • The adhesive strips will need to be replaced after removal.
  4. Acer Iconia One 7 Repairability Assessment: step 4, image 1 of 1
    • Layer of components removable upon opening: power/volume button cable, loudspeaker.
    • The power/volume button cable is lightly secured with adhesive.
    • Two Phillips #0 screws secure the loudspeaker housing.
  5. Acer Iconia One 7 Repairability Assessment: step 5, image 1 of 2 Acer Iconia One 7 Repairability Assessment: step 5, image 2 of 2
    • The display, digitizer, and camera cables can be disconnected without removing the motherboard.
    • The motherboard is secured to the display frame by three Phillips #0 screws.
    • The Micro-USB port, headphone jack and microphone are soldered to the motherboard. These are common failure points and it would be better if they could be individually replaced.
    • The front and rear camera are tethered and will need to be replaced together if one where to fail.
  6. Acer Iconia One 7 Repairability Assessment: step 6, image 1 of 2 Acer Iconia One 7 Repairability Assessment: step 6, image 2 of 2
    • Motherboard reference photos.
  7. Acer Iconia One 7 Repairability Assessment: step 7, image 1 of 2 Acer Iconia One 7 Repairability Assessment: step 7, image 2 of 2
    • The digitizer is fused to the front case but the LCD display can be isolated by unclipping it from the assembly with an opening tool.
  8. Acer Iconia One 7 Repairability Assessment: step 8, image 1 of 2 Acer Iconia One 7 Repairability Assessment: step 8, image 2 of 2
    • The Acer Iconia One 7 earns an 8 out of 10 on our repairability scale (10 is the easiest to repair):
    • LCD and front glass are not fused and can be replaced individually.
    • Battery is easy to replace.
    • Modular design allows replacement of many individual parts.
    • Standard Phillips screws used throughout.
    • High wear components soldered in place, which increases replacement costs.
    • Manufacturer does not provide user-accessible repair documentation.
Finish Line
7 other people completed this guide.
Blake Klein
65,554 Reputation
55 Guides authored
5 Comments
I have an Acer Iconia tablet A500, 32GB RAM, 1GB ROM
I would like to increase my ROM to 4GB ROM, is it possible.
Can you recommend someone or a place that can do this for me?
Thanks, Ginger
email address: ginger41558@outlook.com
ginger41558 - Reply
I have used it very little, sat quietly in a drawer - when I decided to use it, it won’t power up! Sometimes it shows a splash screen with one word on it - ACER (if I remember right). Any idea what might be going on, I’d be grateful - would even give it to someone to revive and use
ruralwannabe - Reply
Estuvo excelente. Gracias y saludos.
Antonio Gomez Gomez - Reply
Is this Acer Iconia One 7 B1-780 (2017) or the older 2014 version?
Daire O Broin - Reply
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 43
All Time: 4,874
