Acer E5-571-54FL WiFi Card Replacement
  1. Acer E5-571-54FL WiFi Card Replacement, Battery: step 1, image 1 of 1
    • Power down the laptop prior to beginning.
    • Turn the laptop over with the battery closest to your body.
  2. Acer E5-571-54FL WiFi Card Replacement: step 2, image 1 of 2 Acer E5-571-54FL WiFi Card Replacement: step 2, image 2 of 2
    • Insert the pointed end of a spudger into the battery release.
    • Slide the release gently all the way to the left.
    • You should hear a sound after the slide is all the way left. This lets you know the battery has disengaged.
  3. Acer E5-571-54FL WiFi Card Replacement: step 3, image 1 of 2 Acer E5-571-54FL WiFi Card Replacement: step 3, image 2 of 2
    • Place your hands on each end of the battery.
    • Pull the battery towards your body to remove it.
  4. Acer E5-571-54FL WiFi Card Replacement, Keyboard: step 4, image 1 of 1
    • Using a #0 Phillips screwdriver, remove a total of eighteen identical 8mm Phillips screws and set them aside.
  5. Acer E5-571-54FL WiFi Card Replacement: step 5, image 1 of 1
    • Rotate the laptop 180 degrees so that the battery compartment is now furthest away from your body.
  6. Acer E5-571-54FL WiFi Card Replacement: step 6, image 1 of 1
    • Turn the laptop over so that you can easily open the screen to a vertical position.
  7. Acer E5-571-54FL WiFi Card Replacement: step 7, image 1 of 1
    • Put your fingers under the top of the keyboard assembly directly below the Acer logo.
    • Carefully pull up on the center until you hear the tabs disengage from the bottom.
  8. Acer E5-571-54FL WiFi Card Replacement: step 8, image 1 of 3 Acer E5-571-54FL WiFi Card Replacement: step 8, image 2 of 3 Acer E5-571-54FL WiFi Card Replacement: step 8, image 3 of 3
    • Work your way around the seam with the plastic opening tool carefully prying the base and top cover apart.
    • If you have difficulty with the plastic opening tool, use a metal spudger but be more cautious to not damage or mar your laptop case.
  9. Acer E5-571-54FL WiFi Card Replacement: step 9, image 1 of 1
    • When the two halves are separated, carefully lift up the front of the keyboard and touchpad assembly.
    • You will see three ribbon cables attached to the motherboard.
  10. Acer E5-571-54FL WiFi Card Replacement: step 10, image 1 of 3 Acer E5-571-54FL WiFi Card Replacement: step 10, image 2 of 3 Acer E5-571-54FL WiFi Card Replacement: step 10, image 3 of 3
    • Closest to the ribbon cable on the zero insertion force (ZIF) connector is a white locking tab.
    • Carefully lift up on the locking tab with the plastic opening tool to release the ribbon cable. (Picture 2)
    • Remove the ribbon cable from the connector.
  11. Acer E5-571-54FL WiFi Card Replacement: step 11, image 1 of 3 Acer E5-571-54FL WiFi Card Replacement: step 11, image 2 of 3 Acer E5-571-54FL WiFi Card Replacement: step 11, image 3 of 3
    • Closest to the ribbon cable on the ZIF connector is a black locking tab.
  12. Acer E5-571-54FL WiFi Card Replacement: step 12, image 1 of 3 Acer E5-571-54FL WiFi Card Replacement: step 12, image 2 of 3 Acer E5-571-54FL WiFi Card Replacement: step 12, image 3 of 3
    • On each side of the large connector there are two white tabs.
    • Carefully push away from you with the plastic opening tool on each white tab to release the cable. (Picture 2)
  13. Acer E5-571-54FL WiFi Card Replacement: step 13, image 1 of 3 Acer E5-571-54FL WiFi Card Replacement: step 13, image 2 of 3 Acer E5-571-54FL WiFi Card Replacement: step 13, image 3 of 3
    • Once all three ribbon cables are disconnected, lift off the top cover with the keyboard and touchpad.
  14. Acer E5-571-54FL WiFi Card Replacement, WiFi Card: step 14, image 1 of 2 Acer E5-571-54FL WiFi Card Replacement, WiFi Card: step 14, image 2 of 2
    • The WiFi card is just below the fan with a white coaxial cable and a black coaxial cable attached.
    • Using ESD safe blunt nose metal tweezers, grab just behind the brass connection on the white coaxial cable attached to the WiFi card.
    • Carefully lift up and forward to disconnect the wire.
    • Repeat both procedure one and two to remove the black coaxial cable.
  15. Acer E5-571-54FL WiFi Card Replacement: step 15, image 1 of 1
    • Using a #0 Phillips screwdriver, remove the 3mm screw from the upper left corner of the WiFi card.
    • The edge of WiFi card will lift up as the screw is removed.
  16. Acer E5-571-54FL WiFi Card Replacement: step 16, image 1 of 2 Acer E5-571-54FL WiFi Card Replacement: step 16, image 2 of 2
    • Grab the upper left corner of the WiFi card with your fingers.
    • Gently pull the WiFi card away from the socket.
Aaron Weissman
1,004 Reputation
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 222
