Introduction
This guide will go through how to replace the touch screen display of the Acer Chromebook Spin 15 CP315-1H-P1K8. Make sure to be careful when replacing the screen, the glass could shatter under pressure.
Flip the computer over so that the back is facing up.
Remove the twelve 6mm Phillips #1 screws from the bottom of the laptop.
Remove the five 6mm Phillips #1 screws from the hinges on either side of the laptop.
3 other people completed this guide.
2 Comments
I just want to say that I’ve used this guide several times. My kid dropped the laptop and broke the hinge which is located inside the top cover behind the LCD panel. When this happened, it caused the grommets to come out of the plastic. But for about $45 we replaced the hinge and the top cover and I was able to fix it and put it all back together. I appreciate having this guide to remind me. Thank you!
Thank you so much for these instructions! The connections were the hardest part for me and the pictures were a great help.
