Introduction
In order to replace the wireless card in your Acer Chromebook R11, follow these steps. You should wear an anti-static wrist strap to avoid damaging your device.
Tools
Parts
Remove eleven 7.23mm Phillips #1 screws from the back panel.
Using a spudger, carefully separate back panel from main body.
The back panel is still attached to the main body by a ribbon cable. Use care not to damage the cable.
Disconnect the two antenna cables (one black and one white) that are attached to the wireless card.
