Shop the Holiday Gift Guide
Acer Chromebook CB0311-1H-C1MX Speaker Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
8
Past 30 Days:
47
All Time:
325
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide will demonstrate the process of removing the speakers for the Acer Chromebook CB0311-1H-C1MX. The speakers are responsible for properly playing sound from the device. If the laptop is not playing sound at the proper volume or quality, then replacing the speakers might resolve the issue.
Before replacing speakers, make sure to check device settings in order to ensure the disoriented sound is not the result of a settings issue.
Tools
  • iFixit Opening Tool
    4.8
  • Spudger
    4.9
    1. Acer Chromebook CB0311-1H-C1MX Speaker Replacement, Back Cover: step 1, image 1 of 1
      • Using a JIS #1 screwdriver, remove eleven 6.6 mm screws from the back cover.
      Ask FixBot
    2. Acer Chromebook CB0311-1H-C1MX Speaker Replacement: step 2, image 1 of 1
      • Beginning at the hinges, use an iFixit Opening Tool to pry open the back case.
      • Continue using the iFixit Opening Tool around the entire edge of the case.
      Ask FixBot
    1. Acer Chromebook CB0311-1H-C1MX Speaker Replacement, Battery: step 3, image 1 of 1
      • Using a JIS #1 screwdriver, remove all four 4.8 mm screws holding the battery in place.
      Ask FixBot
    2. Acer Chromebook CB0311-1H-C1MX Speaker Replacement: step 4, image 1 of 2 Acer Chromebook CB0311-1H-C1MX Speaker Replacement: step 4, image 2 of 2
      • Gently push on either side of the silver connector so that it no longer covers the battery cable.
      • Disconnect the battery cable by pulling it straight out.
      • This component is called the Flat Topped Connector.
      Ask FixBot
    3. Acer Chromebook CB0311-1H-C1MX Speaker Replacement: step 5, image 1 of 2 Acer Chromebook CB0311-1H-C1MX Speaker Replacement: step 5, image 2 of 2
      • Lift and remove the battery from the laptop.
      Ask FixBot
    1. Acer Chromebook CB0311-1H-C1MX Speaker Replacement, Speaker: step 6, image 1 of 2 Acer Chromebook CB0311-1H-C1MX Speaker Replacement, Speaker: step 6, image 2 of 2
      • Disconnect the speaker cable from the motherboard by pulling it straight out.
      Ask FixBot
    2. Acer Chromebook CB0311-1H-C1MX Speaker Replacement: step 7, image 1 of 2 Acer Chromebook CB0311-1H-C1MX Speaker Replacement: step 7, image 2 of 2
      • Lift the speaker out, taking care to unweave the cord from the metal prongs.
      • There may be tape holding down parts of the speaker.
      Ask FixBot
2 other people completed this guide.
Author
with
Sami Suplizio
609 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 47
All Time: 325
