Acer Chromebook CB0311-1H-C1MX Heatsink Replacement
    1. Acer Chromebook CB0311-1H-C1MX Heatsink Replacement, Back Cover: step 1, image 1 of 1
      • Using a JIS #1 screwdriver, remove eleven 6.6 mm screws from the back cover.
      Ask FixBot
    2. Acer Chromebook CB0311-1H-C1MX Heatsink Replacement: step 2, image 1 of 1
      • Beginning at the hinges, use an iFixit Opening Tool to pry open the back case.
      • Continue using the iFixit Opening Tool around the entire edge of the case.
      Ask FixBot
    1. Acer Chromebook CB0311-1H-C1MX Heatsink Replacement, Battery: step 3, image 1 of 1
      • Using a JIS #1 screwdriver, remove all four 4.8 mm screws holding the battery in place.
      Ask FixBot
    2. Acer Chromebook CB0311-1H-C1MX Heatsink Replacement: step 4, image 1 of 2 Acer Chromebook CB0311-1H-C1MX Heatsink Replacement: step 4, image 2 of 2
      • Gently push on either side of the silver connector so that it no longer covers the battery cable.
      • Disconnect the battery cable by pulling it straight out.
      • This component is called the Flat Topped Connector.
      Ask FixBot
    3. Acer Chromebook CB0311-1H-C1MX Heatsink Replacement: step 5, image 1 of 2 Acer Chromebook CB0311-1H-C1MX Heatsink Replacement: step 5, image 2 of 2
      • Lift and remove the battery from the laptop.
      Ask FixBot
    1. Acer Chromebook CB0311-1H-C1MX Heatsink Replacement, Heatsink: step 6, image 1 of 2 Acer Chromebook CB0311-1H-C1MX Heatsink Replacement, Heatsink: step 6, image 2 of 2
      • Remove all four 4.7 mm screws from the heat sink with the JIS #1 screwdriver.
      Ask FixBot
    2. Acer Chromebook CB0311-1H-C1MX Heatsink Replacement: step 7, image 1 of 1
      • Remove the heatsink from the laptop.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 15
Past 30 Days: 61
All Time: 266
