Acer Chromebook C740 LCD Screen Replacement
  1. Acer Chromebook C740 LCD Screen Replacement, LCD Screen: step 1, image 1 of 1
    • Power down the Chromebook and disconnect the power adapter.
  2. Acer Chromebook C740 LCD Screen Replacement: step 2, image 1 of 2 Acer Chromebook C740 LCD Screen Replacement: step 2, image 2 of 2
    • With the Chromebook open and face up, pry the black screen frame with your fingers.
    • Move slowly around the display to evenly remove it.
    • Clicking sounds indicate the panel is seperating from the overall display.
  3. Acer Chromebook C740 LCD Screen Replacement: step 3, image 1 of 1
    • Once the frame is separated from the display, angle the display assembly back .
    • Lift up the portions of the frame covering the front two hinges with the spudger.
  4. Acer Chromebook C740 LCD Screen Replacement: step 4, image 1 of 1
    • Remove the frame from the screen assembly by pulling the frame towards you.
    • Some adjustment of the display assembly may be needed so that the frame is not stuck near the hinges.
  5. Acer Chromebook C740 LCD Screen Replacement: step 5, image 1 of 2 Acer Chromebook C740 LCD Screen Replacement: step 5, image 2 of 2
    • Remove the six 3.35mm screws with a Phillips #0 Screwdriver.
  6. Acer Chromebook C740 LCD Screen Replacement: step 6, image 1 of 3 Acer Chromebook C740 LCD Screen Replacement: step 6, image 2 of 3 Acer Chromebook C740 LCD Screen Replacement: step 6, image 3 of 3
    • Place the LCD screen face down on the keyboard.
    • Remove the tape holding the black connector in place.
    • Unplug the connector with your hands.
7 other people completed this guide.
Grace Bassett
217 Reputation
1 Guide authored
Cal Poly, Team S22-G2, Livingston Spring 2017 Member of Cal Poly, Team S22-G2, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G2
4 Members
12 Guides authored
One Comment
You actually don’t need to unscrew the middle screws, and you don’t need to buy a new bezel.
Keith Hudson - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 21
All Time: 3,307
