Introduction
This guide will help you identify, remove, and potentially replace the power jack harness within the Acer Aspire V5-591G-75KE.
Close down the display and flip the device upside down.
Use a Phillips #1 screwdriver to remove 18 black 10mm Phillips Head screws in order to loosen up the protective bottom casing.
Locate the power jack harness on the upper left quadrant of your device.
Note where the power jack harness connects to the mother board of your device.
3 Comments
Okay, so I did fix this… But after we booted up the sound stopped working. I was very careful, but maybe knocked something? Any suggestions much appreciated.
Thank you
Check the step where you open the case. There is a cable you need to remove thats holding the case to the laptop. Just link that back to where it was and it should work
hrstg -
