Acer Aspire V5-591G-75KE Laptop Battery Replacement
  1. Acer Aspire V5-591G-75KE Laptop Battery Replacement, Acer Aspire V5-591G-75KE Disassembly: step 1, image 1 of 3 Acer Aspire V5-591G-75KE Laptop Battery Replacement, Acer Aspire V5-591G-75KE Disassembly: step 1, image 2 of 3 Acer Aspire V5-591G-75KE Laptop Battery Replacement, Acer Aspire V5-591G-75KE Disassembly: step 1, image 3 of 3
    • Close down the display and flip the device upside down.
    • Use a Phillips #1 screwdriver to remove 18 black 10mm Phillips Head screws in order to loosen up the protective bottom casing.
  2. Acer Aspire V5-591G-75KE Laptop Battery Replacement: step 2, image 1 of 2 Acer Aspire V5-591G-75KE Laptop Battery Replacement: step 2, image 2 of 2
    • With the screws removed, flip the device right-side up and open up the display.
    • Run a plastic spudger tool along the seam of the face-plate in order to loosen up the protective bottom casing.
    • Popping sounds are normal, but forceful prying can damage delicate components. Be especially careful near the USB and HDMI ports.
  3. Acer Aspire V5-591G-75KE Laptop Battery Replacement: step 3, image 1 of 2 Acer Aspire V5-591G-75KE Laptop Battery Replacement: step 3, image 2 of 2
    • Close the display down once more, and flip the laptop upside down, with the hinge facing away from you.
    • Do not yank the bottom casing off. There is a small speaker wire that connects it to the motherboard.
    • Taking note of the small speaker wire, gently lift only the left side of the bottom casing.
  4. Acer Aspire V5-591G-75KE Laptop Battery Replacement: step 4, image 1 of 3 Acer Aspire V5-591G-75KE Laptop Battery Replacement: step 4, image 2 of 3 Acer Aspire V5-591G-75KE Laptop Battery Replacement: step 4, image 3 of 3
    • Using a pair of blunt tweezers, push on the tabs of the small white connector to separate it from the motherboard.
    • The entire bottom casing should lift with no resistance. If there is too much resistance, verify you removed all the screws, and run the plastic spudger tool around the face-plate again.
  5. Acer Aspire V5-591G-75KE Laptop Battery Replacement, Laptop Battery: step 5, image 1 of 2 Acer Aspire V5-591G-75KE Laptop Battery Replacement, Laptop Battery: step 5, image 2 of 2
    • The laptop battery is the black rectangular item at the top.
    • The battery connects to the motherboard via a multi-colored 8-pin connector.
    • Using a pair of blunt tweezers, push the white tabs on the sides 8-pin connector to disconnect the battery from the motherboard.
  6. Acer Aspire V5-591G-75KE Laptop Battery Replacement: step 6, image 1 of 1
    • Lift the battery directly up to remove it from the laptop. It is not screwed on.
Tasier Hagler
428 Reputation
4 Guides authored
UW Tacoma, Team S3-G5, Liner Fall 2017 Member of UW Tacoma, Team S3-G5, Liner Fall 2017
UWT-LINER-F17S3G5
4 Members
18 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 2,213
