Acer Aspire V5-572, V5-572G Memory (RAM) Upgrade
Video Overview
  1. Acer Aspire V5-572, V5-572G Memory (RAM) Upgrade, Bottom Cover: step 1, image 1 of 1
    • Switch-off the Laptop.
    • Remove the seventeen Philips #0 screws.
  2. Acer Aspire V5-572, V5-572G Memory (RAM) Upgrade: step 2, image 1 of 1
    • If there is a plastic storage tray in the laptop, remove it.
  3. Acer Aspire V5-572, V5-572G Memory (RAM) Upgrade: step 3, image 1 of 3 Acer Aspire V5-572, V5-572G Memory (RAM) Upgrade: step 3, image 2 of 3 Acer Aspire V5-572, V5-572G Memory (RAM) Upgrade: step 3, image 3 of 3
    • Starting from the SD Memory Card hole, start prying between the top and bottom cases.
    • Use plastic tools to avoid damaging the cover.
    • Remove the bottom case.
    Love the tutorial man...but this is the most moronic thing I've ever seen...you can take batery out of laptop 15 years old in a flash, while here you have to disassemble the whole %#*@ laptop...only idiots can come up with something like that
    razbojnikkuro - Reply
    I have to agree that this is extremely complicated and intense.
    There is no way your average user should be doing this and the average user should be able to replace the battery!!
    Like everything in the computer world, hardware or software, ease of use is no longer even a consideration!!
    Technical Support Bots are the rule and they rarely are up to date with the pages on the website!!
    Sucks!!
    andy.cox - Reply
  4. Acer Aspire V5-572, V5-572G Memory (RAM) Upgrade: step 4, image 1 of 1
    • Disconnect the battery immediately for a safer repair.
    • Pull the battery connector away from the hard drive to disconnect it.
  5. Acer Aspire V5-572, V5-572G Memory (RAM) Upgrade, Memory (RAM): step 5, image 1 of 3 Acer Aspire V5-572, V5-572G Memory (RAM) Upgrade, Memory (RAM): step 5, image 2 of 3 Acer Aspire V5-572, V5-572G Memory (RAM) Upgrade, Memory (RAM): step 5, image 3 of 3
    • This model have 1x Memory Slot.
    • You can upgrade your laptop with SODIMM DDR3 ram at 1333 or 1600.
6 other people completed this guide.
ZFix
191,055 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
322 Members
2,506 Guides authored
One Comment
Hi,
While adding an extra RAM to the module in Aspire V5-472, I forgot to disconnnect the battery first.
I first tried 4 GB RAM compatible, SODIMMM- DDR3L 204-Pin Laptop Memory, Low Voltage. When that didn't work, I checked again.
Next time I disconnected the battery, and repeated the process with 2 GB RAM, compatible, SODIMMM- DDR3L 204-Pin Laptop Memory, Low Voltage. The RAM was still not discovered. None of the RAMs were detected.
Hope I haven't fried the RAM Module itself.
Please help.
Indi Shukla - Reply
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 82
All Time: 22,668
