Acer Aspire V5-572, V5-572G Mainboard Replacement
Video Overview
  1. Acer Aspire V5-572, V5-572G Mainboard Replacement, Bottom Cover: step 1, image 1 of 1
    • Switch-off the Laptop.
    • Remove the seventeen Philips #0 screws.
  2. Acer Aspire V5-572, V5-572G Mainboard Replacement: step 2, image 1 of 1
    • If there is a plastic storage tray in the laptop, remove it.
  3. Acer Aspire V5-572, V5-572G Mainboard Replacement: step 3, image 1 of 3 Acer Aspire V5-572, V5-572G Mainboard Replacement: step 3, image 2 of 3 Acer Aspire V5-572, V5-572G Mainboard Replacement: step 3, image 3 of 3
    • Starting from the SD Memory Card hole, start prying between the top and bottom cases.
    • Use plastic tools to avoid damaging the cover.
    • Remove the bottom case.
  4. Acer Aspire V5-572, V5-572G Mainboard Replacement: step 4, image 1 of 1
    • Disconnect the battery immediately for a safer repair.
    • Pull the battery connector away from the hard drive to disconnect it.
  5. Acer Aspire V5-572, V5-572G Mainboard Replacement, Battery: step 5, image 1 of 1
    • Remove the single Phillips 0 screw securing the battery.
  6. Acer Aspire V5-572, V5-572G Mainboard Replacement: step 6, image 1 of 1
    • Remove the battery
  7. Acer Aspire V5-572, V5-572G Mainboard Replacement, HDD: step 7, image 1 of 3 Acer Aspire V5-572, V5-572G Mainboard Replacement, HDD: step 7, image 2 of 3 Acer Aspire V5-572, V5-572G Mainboard Replacement, HDD: step 7, image 3 of 3
    • Disconnect the SATA Cable from the Mother Board.
    • Take out the HDD and remove the SATA cable from it.
    • Now you can change / upgrade your HDD.
  8. Acer Aspire V5-572, V5-572G Mainboard Replacement, Wi-Fi half mini PCIe card: step 8, image 1 of 3 Acer Aspire V5-572, V5-572G Mainboard Replacement, Wi-Fi half mini PCIe card: step 8, image 2 of 3 Acer Aspire V5-572, V5-572G Mainboard Replacement, Wi-Fi half mini PCIe card: step 8, image 3 of 3
    • Remove 1x screw and disconnect the two antenna coaxial cables.
    • Remove the Wi-Fi card from the slot.
  9. Acer Aspire V5-572, V5-572G Mainboard Replacement, Cooling / Fan System: step 9, image 1 of 2 Acer Aspire V5-572, V5-572G Mainboard Replacement, Cooling / Fan System: step 9, image 2 of 2
    • Disconnect the Fan cable.
    • Remove the three screws from the CPU cooler and one from the Fan module.
    • When you change the Cooling system, you must clean the processor from old thermal compound and put new.
  10. Acer Aspire V5-572, V5-572G Mainboard Replacement, Mainboard: step 10, image 1 of 3 Acer Aspire V5-572, V5-572G Mainboard Replacement, Mainboard: step 10, image 2 of 3 Acer Aspire V5-572, V5-572G Mainboard Replacement, Mainboard: step 10, image 3 of 3
    • Disconnect one by one:
    • LCD Display flex cable
    • DC Jack cable
    • USB Board flex cable
    • Touch pad flex cable
    • Keyboard flex cable
  11. Acer Aspire V5-572, V5-572G Mainboard Replacement: step 11, image 1 of 3 Acer Aspire V5-572, V5-572G Mainboard Replacement: step 11, image 2 of 3 Acer Aspire V5-572, V5-572G Mainboard Replacement: step 11, image 3 of 3
    • Disconnect the Loudspeakers and the Microphone cables.
    • Remove 6x Phillips screws, 3x from the Main board and 3x from the hinge.
    • Open a little the laptop to open the hinge.
    • By hand, open the hinge to the end.
  12. Acer Aspire V5-572, V5-572G Mainboard Replacement: step 12, image 1 of 3 Acer Aspire V5-572, V5-572G Mainboard Replacement: step 12, image 2 of 3 Acer Aspire V5-572, V5-572G Mainboard Replacement: step 12, image 3 of 3
    • Carefully remove the the Main board.
ZFix
191,182 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
322 Members
2,521 Guides authored
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 17
All Time: 4,636
