You're viewing a previously published version of this guide.  View latest version
Older Newer
Introduction
Aspire V5-572, V5-572G - how to remove the Bottom cover.
Video Overview
  1. Switch-off the Laptop.
    • Switch-off the Laptop.
    • Remove the seventeen Philips #0 screws.
  2. If there is a plastic storage tray in the laptop, remove it.
    • If there is a plastic storage tray in the laptop, remove it.
  3. Starting from the SD Memory Card hole, start prying between the top and bottom cases. Use plastic tools to avoid damaging the cover. Remove the bottom case.
    • Starting from the SD Memory Card hole, start prying between the top and bottom cases.
    • Use plastic tools to avoid damaging the cover.
    • Remove the bottom case.
  4. Disconnect the battery immediately for a safer repair.
    • Disconnect the battery immediately for a safer repair.
    • Pull the battery connector away from the hard drive to disconnect it.
ZFix
181,544 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
300 Members
1,016 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 9
All Time: 3,304
