Acer Aspire R7-572-6423 Battery Replacement
  1. Acer Aspire R7-572-6423 Battery Replacement, Battery: step 1, image 1 of 1
    • Turn off the laptop and disconnect the power adapter before attempting this guide. Failure to do so can result in a shock hazard.
  2. Acer Aspire R7-572-6423 Battery Replacement: step 2, image 1 of 2 Acer Aspire R7-572-6423 Battery Replacement: step 2, image 2 of 2
    • Remove the top and middle rubber feet under the laptop to reveal hidden screws.
  3. Acer Aspire R7-572-6423 Battery Replacement: step 3, image 1 of 1
    • Remove the five 6 mm T9 screws.
    • Remove the eight 10 mm T9 screws.
  4. Acer Aspire R7-572-6423 Battery Replacement: step 4, image 1 of 1
    • Remove the back cover.
  5. Acer Aspire R7-572-6423 Battery Replacement: step 5, image 1 of 1
    • Unplug the ribbon cable connecting the battery to the motherboard.
    • Be careful around the motherboard, as it is easily damaged.
  6. Acer Aspire R7-572-6423 Battery Replacement: step 6, image 1 of 1
    • Remove the three 4 mm Phillips #1 screws securing the battery.
  7. Acer Aspire R7-572-6423 Battery Replacement: step 7, image 1 of 2 Acer Aspire R7-572-6423 Battery Replacement: step 7, image 2 of 2
    • Pull open the clips on either side of the battery to free it from the case.
    • Remove the battery from the computer.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 7
All Time: 1,744
