Acer Aspire One ZG5 Wireless Card Replacement
  1. Acer Aspire One ZG5 Wireless Card Replacement, Battery: step 1, image 1 of 1
    • Turn the netbook upside down with the battery at the top, facing away from you.
  2. Acer Aspire One ZG5 Wireless Card Replacement: step 2, image 1 of 1
    • Unlock the battery by sliding the switch located near the left hinge to the left "unlocked" position.
  3. Acer Aspire One ZG5 Wireless Card Replacement: step 3, image 1 of 1
    • Slide the latch located on the opposite hinge from the lock while pushing the battery up.
  4. Acer Aspire One ZG5 Wireless Card Replacement, Wireless Card: step 4, image 1 of 1
    • Gently loosen the two Phillips #0 screws in the small panel that covers the wireless card.
    • These screws are built into the panel and aren't meant to be completely removed.
  5. Acer Aspire One ZG5 Wireless Card Replacement: step 5, image 1 of 1
    • Lift up the panel and remove it from the case.
  6. Acer Aspire One ZG5 Wireless Card Replacement: step 6, image 1 of 1
    • Disconnect the two antenna cables from the left side of the wireless card.
  7. Acer Aspire One ZG5 Wireless Card Replacement: step 7, image 1 of 1
    • Remove the single 3.9 mm Phillips #1 screw from the bottom left of the wireless card.
  8. Acer Aspire One ZG5 Wireless Card Replacement: step 8, image 1 of 1
    • Gently lift up the left side of the wireless card and slide the card out of its socket.
Doug Gallatin
6,337 Reputation
10 Guides authored
Cal Poly, Team 7-49, Amido Fall 2010 Member of Cal Poly, Team 7-49, Amido Fall 2010
CPSU-AMIDO-F10S7G49
5 Members
27 Guides authored
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 17
All Time: 23,524
