Introduction
This is a basic first step to working on any of the components under the cover. Be sure to have a space to store the screws while working on the device so that you do not lose any of them.
Parts
No parts required.
  1. Unscrew the 13 6.2mm screws located on the bottom of the laptop using the JIS #0 screwdriver.
    • Unscrew the 13 6.2mm screws located on the bottom of the laptop using the JIS #0 screwdriver.
  2. Using a plastic opening tool, gently pry the lower case off. Place aside.
    • Using a plastic opening tool, gently pry the lower case off. Place aside.
Mason Devinney
346 Reputation
3 Guides authored
USF Tampa, Team S3-G1, Cannon Fall 2017 Member of USF Tampa, Team S3-G1, Cannon Fall 2017
USFT-CANNON-F17S3G1
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 7
All Time: 111
