You're viewing a previously published version of this guide.  View latest version
Older Newer
Introduction
This guide will show you how to replace a broken keyboard.
Parts
No parts specified.
  1. Press and slide battery-lock button to remove the battery. Press and slide battery-lock button to remove the battery.
    • Press and slide battery-lock button to remove the battery.
  2. Remove 17x Philips screws
    • Remove 17x Philips screws
  3. Remove the plastic cover
    • Remove the plastic cover
    • Remove 2x Philips screws
  4. Start opening the top starting at the side of the screen Use plastic tools to avoid damaging the cover. Use plastic tools to avoid damaging the cover.
    • Start opening the top starting at the side of the screen
    • Use plastic tools to avoid damaging the cover.
  5. Disconnect 3x flex cables Disconnect 3x flex cables Disconnect 3x flex cables
    • Disconnect 3x flex cables
  6. Remove 6x Philips screws
    • Remove 6x Philips screws
    • The 2 Philips screws at the top are different from the other 4 (thicker)
    • Remove 3x small (silver) Philips screws
  7. Remove the metal plate by sliding it up and then flipping it over
    • Remove the metal plate by sliding it up and then flipping it over
    • Be careful to not damage the flex cable attached to the metal plate.
  8. Disconnect 2x aluminium grounding
    • Disconnect 2x aluminium grounding
    • Lift the keyboard out
Sander Degryse
284 Reputation
1 Guide authored
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 50
All Time: 6,299
