Acer Aspire 5100 Motherboard Replacement
  1. Acer Aspire 5100 Motherboard Replacement, Fan: step 1, image 1 of 1
    • Flip the laptop upside-down.
    • Remove the battery as a safety precaution.
    • Remove the four screws attached to the large panel.
  2. Acer Aspire 5100 Motherboard Replacement: step 2, image 1 of 1
    • Lift and remove the panel.
  3. Acer Aspire 5100 Motherboard Replacement: step 3, image 1 of 1
    • Remove the two screws attached to the fan.
  4. Acer Aspire 5100 Motherboard Replacement: step 4, image 1 of 2 Acer Aspire 5100 Motherboard Replacement: step 4, image 2 of 2
    • Lift the fan and detach the cable that connects the fan to the motherboard.
    • The fan can break easily. Be careful when removing.
    • When detaching the cable, do not pull on the cable itself. Instead, use a small spudger to detach it at the white section that connects it to the motherboard.
  5. Acer Aspire 5100 Motherboard Replacement, Keyboard: step 5, image 1 of 2 Acer Aspire 5100 Motherboard Replacement, Keyboard: step 5, image 2 of 2
    • Open and push the screen back all the way until it is horizontal with the rest of the laptop.
    • Use an opening tool to remove the panel above the keyboard that has the power button on it.
    • After you have released the tabs, lift up the panel.
  6. Acer Aspire 5100 Motherboard Replacement: step 6, image 1 of 3 Acer Aspire 5100 Motherboard Replacement: step 6, image 2 of 3 Acer Aspire 5100 Motherboard Replacement: step 6, image 3 of 3
    • Under the panel, remove the two screws that connect the keyboard to the laptop.
    • One screw is located above the F5 button, and the other one is located above the F10 button.
    • Potential for device damage: Lift up the keyboard CAREFULLY because there is a ribbon that connects the keyboard to the motherboard.
  7. Acer Aspire 5100 Motherboard Replacement: step 7, image 1 of 1
    • Release the catch on the ribbon socket by sliding the two tabs toward the ribbon.
    • Pull the ribbon under the keyboard to detach it from the motherboard.
    • Remove the keyboard.
  8. Acer Aspire 5100 Motherboard Replacement, Track Pad: step 8, image 1 of 1
    • Remove the nine screws from the back edges of the laptop.
  9. Acer Aspire 5100 Motherboard Replacement: step 9, image 1 of 3 Acer Aspire 5100 Motherboard Replacement: step 9, image 2 of 3 Acer Aspire 5100 Motherboard Replacement: step 9, image 3 of 3
    • Open the lid of the laptop and locate the cover that surrounds the keyboard and track pad.
    • Use the spudger to pry open the sides of this cover.
    • DO NOT lift cover off after detaching it because the track pad is connected to the motherboard.
  10. Acer Aspire 5100 Motherboard Replacement: step 10, image 1 of 2 Acer Aspire 5100 Motherboard Replacement: step 10, image 2 of 2
    • Slightly lift up the cover to see the ribbon connection.
    • Release the catch by sliding the two lugs toward the ribbon, then pull the ribbon to detach it from the motherboard.
    • Lift up the cover from the laptop.
  11. Acer Aspire 5100 Motherboard Replacement: step 11, image 1 of 1
    • On the cover that was removed, flip it around and locate where the back of the track pad is.
    • Remove the three screws located at the corners.
    • Lift up the bracket that you just unscrewed and remove track pad.
  12. Acer Aspire 5100 Motherboard Replacement, LCD Monitor: step 12, image 1 of 1
    • Remove the two screws from each corner beneath the LCD screen.
  13. Acer Aspire 5100 Motherboard Replacement: step 13, image 1 of 2 Acer Aspire 5100 Motherboard Replacement: step 13, image 2 of 2
    • Detach the white rectangle located on the motherboard at the end of the wire connected to the LCD screen.
  14. Acer Aspire 5100 Motherboard Replacement: step 14, image 1 of 2 Acer Aspire 5100 Motherboard Replacement: step 14, image 2 of 2
    • Flip the laptop upside down.
    • Remove the four screws from the back panel of the laptop.
    • Lift the panel up and set it aside.
  15. Acer Aspire 5100 Motherboard Replacement: step 15, image 1 of 1
    • Detach the black and white wire.
    • You do not need to remove the cooling fan.
  16. Acer Aspire 5100 Motherboard Replacement: step 16, image 1 of 1
    • Lift up the monitor to detach it.
  17. Acer Aspire 5100 Motherboard Replacement, Motherboard: step 17, image 1 of 1
    • Locate and remove the screws on the motherboard.
    • There is normally only one remaining screw holding the board. Bottom right (sometimes under tape).
    • All the other screw holes except screws holding the base cover on and are kept empty.
  18. Acer Aspire 5100 Motherboard Replacement: step 18, image 1 of 1
    • Locate the heat sink, which is the copper "L" shaped component, and unscrew the four screws that connect it to the motherboard.
  19. Acer Aspire 5100 Motherboard Replacement: step 19, image 1 of 1
    • Find the VGA connector located next to the USB ports.
    • Push out the back of the casing by the VGA connector to be able to get the motherboard out.
  20. Acer Aspire 5100 Motherboard Replacement: step 20, image 1 of 2 Acer Aspire 5100 Motherboard Replacement: step 20, image 2 of 2
    • Lift up and remove the motherboard from the laptop casing.
    • Remove the USB add-on card to use it with the new motherboard.
    • To remove, grab on the sides and lift upward.
Brad Rollinson
1,113 Reputation
7 Guides authored
Cal Poly, Team 14-39, Forte Fall 2010 Member of Cal Poly, Team 14-39, Forte Fall 2010
CPSU-FORTE-F10S14G39
5 Members
10 Guides authored
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 19
All Time: 44,344
