Introduction
This step by step guide will show you how to replace the CPU in your Acer Aspire 5100.
Open and push the screen back all the way until it is horizontal with the rest of the laptop.
Use an opening tool to remove the panel above the keyboard that has the power button on it.
After you have released the tabs, lift up the panel.
Under the panel, remove the two screws that connect the keyboard to the laptop.
Release the catch on the ribbon socket by sliding the two tabs toward the ribbon.
Pull the ribbon under the keyboard to detach it from the motherboard.
Remove the keyboard.
do not pull on ribbon it will only break the cable. instead use tool to detach from mother board. i broke mine by pulling ribbon.
useless guide, there are a lot of screws that lock the cover on the laptop and you have never showed them
You do not need to remove the whole cover, in order to replace the keyboard.
The description for this job is right.
The switch plate cover just pops off.
Screws revealed, secure the keyboard.
Unclip the ribbon cable.
Job done
Richard -
Remove the nine screws from the back edges of the laptop.
Loosen the screw to the CPU by rotating counter clockwise. The use of a flat head screwdriver will be needed.
2 Comments
Hello sir
Can I switch to cpu amd advanced chip intel or I can not do so
Thank you
Message me on email
rabaharif1993@gmail.com
4screws 10mm
dhsttite@hotmail.com - Reply
4 screws 10mm.
